Tractor Talk Discussion Forum
Which one would you use??
old
06-19-2007 18:43:24
Have an Allis haybine/moco that I have back up and running. So which tractor to hook it to. Either a WD45 or a D-17?? I have others I could use but both of these are just sitting wanting some thing to do. Which would you use??
Thanks
Roger in Iowa
06-20-2007 05:59:00
 Re: Which one would you use?? in reply to old, 06-19-2007 18:43:24
Doesn't the D-17 have live PTO? I am sure the WD doesn't or does it have the wierd clutch arrangement?
Anyway, live pto is the way to go.
Roger in Iowa
old
06-20-2007 07:09:54
 Re: Which one would you use?? in reply to Roger in Iowa, 06-20-2007 05:59:00
Well the WD45 has a hand clutch give it live PTO and the D-17 has the power divider which also gives it live PTO so on that one it doesn't matter since both have a form of live PTO. The WD45 is around 43HP and the D-17 about 10 more HP. I'll probably go with the D-17 because of the power steering
JRT
06-19-2007 21:46:22
That is a no brainer. Use the D 17. If you have a healthy back now, about 3 hours on that wd45 would put you in traction. Those have got to be the most uncomfortable tractor ever made. A good tractor though. What a shame they made it so primitive.
Leland
06-19-2007 20:24:09
I agree the D-17 would handle it better and make it easier on you as well
Larry in Mo
06-19-2007 19:13:14
 ! in reply to old, 06-19-2007 18:43:24
Old: I'd use the WD45. Keeps your joints limbered up getting on and off! LE
RustyFarmall
06-19-2007 19:00:16
I haven't been on either tractor more than just a few times, but I definately think the D-17 has a better ride.
glennster
06-19-2007 18:59:54
if ya got a straw hat, red bandanna and bib overhauls, go with the wd !!!i always got stuck stacking on the hayrack, never got to drive... :-(. i was down in your neck of the woods last week, went to mountain home ark for a week. on 63 from rolla to west plains, saw quite a few old propane tractors there. they are few and far between up here in northern ill. propane must have been a popular choice back then in missouri.
old
06-19-2007 21:16:41
 Re: Which one would you use?? in reply to glennster, 06-19-2007 18:59:54
Shoot you where with in 50 miles of me, you should have called and stoped by. In my area I don't see many propane tractors and have never owned one either
glennster
06-20-2007 06:08:09
 Re: Which one would you use?? in reply to old, 06-19-2007 21:16:41
next time i go down there i'll give you a holler and stop in for a visit. was supposed to vacation last week, stayed on lake norfork, was gonna relax, maybe fish, snooze ect. we bought 6 acres of woods, ticks and chiggers last year there, momma decided i should do some work, wound up cutting back cedar trees, and mowing up the ditches and stuff. turned out to be a workin vacation. i gotta go sometime with the trailer empty, whole bunch of old iron all over down there that would look real nice in my barn. cant tell momma tho....lot of guys were cutting hay too, gotta be tough in that heat!!!!
old
06-20-2007 07:06:51
 Re: Which one would you use?? in reply to glennster, 06-20-2007 06:08:09
Yep it can be hot going cutting hay in this area. Just think if its hot cutting what its like getting this old haybine back up and running. Spent the last 4 days on it and probably have at least one more day to finish all the small stuff before I put it to work.
