Tractor Talk Discussion Forum
Why???
Stan(PA)
05-13-2004 05:34:17
Why does it seem that almost every compression test result shows #3 as the low cylinder. I just noticed that it seems to be #3 eveytime anyone reports compression numbers.
JMS/MN
05-13-2004 22:19:29
 Re: Why??? in reply to Stan(PA), 05-13-2004 05:34:17
If you go to www.satan.com and divide his favorite number, ie: 666, by 222, you get 3, which is why the #3 cylinder always goes bad, just like on my D17!!!!! !!! Of course, it might be because of the guy that did the overhaul a few years ago..... ..just like the overhaul on the 3020, and I don't deal with him anymore, even if he's my third cousin! (which is TRUE).
Vern-MI
05-13-2004 13:32:17
Had a '57 Volkswagon that kept burning the #3 exhaust valve. Put new heads on it and the #3 exhaust valve in those heads burned also.
buickanddeere
05-13-2004 13:56:25
 Re: Re: Why??? in reply to Vern-MI, 05-13-2004 13:32:17
The VW hung the oil cooler over #3 cylinder. Therefore #3 cylinder ran warmer with less and hotter air.
RN
05-13-2004 22:08:39
 Re: Re: Re: Why??? in reply to buickanddeere, 05-13-2004 13:56:25
VW oil cooler exit outside of fan shroud about 1972?, #3 a bit cooler then. RN
txblu
05-13-2004 10:06:43
I'm gonna guess it is because coolant enters from the front so the front gets flushed first and last and the most.
RAB
05-13-2004 08:17:38
First one the sh*t or grit flies into? Perhaps that one runs richer than the rest - well, ok, it will probably on a spark ignition engine, as the fuel distribution will not be perfect and the rest will even out due to some turbulence in those old manifolds. Running a little hotter than the others due to cooling system build-up (or cooler due to mixture differences).
Need I think of any more?
Regards, RAB
Mike M
05-13-2004 06:51:00
Try going over to the John Deere board. They don't have that problem over there. Why? you ask.
#1,#2 and that's it!
harley1983
05-13-2004 20:15:16
 Re: Re: Why??? in reply to Mike M, 05-13-2004 06:51:00
Yeh, Mike, and we better hope that J D drivers never figure out how to hook up those other two cylinders or us red guys could be in trouble. I think if they did they just might have a real tractor there. Harley
txblu
05-13-2004 10:05:27
That is funny. LOL.
That is funny!
05-13-2004 10:20:24
 Re: Re: Re: Why??? in reply to txblu, 05-13-2004 10:05:27
There's somebody with Cub comp readings on the Farmall board, and it is #3 again.
