Tractor Talk Discussion Forum
Farmall 1206 hydraulic problems
dano
08-05-2004 19:23:13
My brother is experiencing intense problems with his 1206. The hydraulic circuit must have a major leak. When the tractor is in gear and moving, then you turn the steering wheel at all, the clutch pressure drops and disengages. We"ve already re-sealed the MCV and steering unit behind the batteries, but no help. According to the manual, we need to pull the front bolster off of the tractor and re seal the steering motor, but I wanted anyone"s input if they"ve experinced this before with their tractor. If it"s a failing aux. pump or manual steering motor behind the steering wheel, I"d much rather do that than remove the nose of the tractor for the steering motor if that"s not the problem. We just don"t want to stab in the dark. Any assistance would be appreciated. Thanks!
Paul K.
08-09-2004 19:48:22
 Re: Farmall 1206 hydraulic problems in reply to dano, 08-05-2004 19:23:13
Hi Dano. Have you been able to remedy your problem with the hydraulics? My brother has an 806 that is acting exactly like you describe your 1206. Could use some help if you find anything out. Thanks
bernard le mécano
08-06-2004 09:36:11
Hi Dano, may be the key on the MCV pump shaft is broken or check for a bad relief valve. When the steering is off, does the hitch, remote and PTO work? May be broken splines on the pressure plate and PTO shaft. Bernard le mécano Québec Canada
Bob
08-05-2004 21:05:35
Check the output of the pump with a flow meter, against spec's.
