Tractor Talk Discussion Forum
New tall 42/46 tires vs. old 38.
Mopower
08-06-2004 05:07:02
I see many farmers replacing their 18.4x38" tires with the new 42 or 46". I am looking to bump up our Moline M5 to 18.4 x 38" from old 34". Anyone got 18.4x38 with nice tread? Radials are even ok. What's with all the super tall ones these days? Working well huh?
JMS/MN
08-06-2004 19:12:31
 Re: New tall 42/46 tires vs. old 38. in reply to Mopower, 08-06-2004 05:07:02
Around here the ones going to 42/46 are generally sugar beet farmers, who plant in 22 inch rows. They want taller, narrower tires to give good traction in the narrower rows. Less rubber width on the ground needs bigger diameter to maintain same traction. They go to 22 inch corn/soybean planters as well, like their beet planters, so the same tractor & equipment (cultivator, sprayer) can be used on all crops.
kyhayman
08-06-2004 13:17:24
I've got 1 good 38" Michelan radial rear. (and 1 with a split side wall). email is unmasked.
TheRealRon
08-06-2004 11:36:44
www.millertire.com
TimFL
08-06-2004 08:41:38
Make sure you can get rims first. Taller tires are useless w/o rims.
Mopower
08-06-2004 10:22:14
 Re: New tall 42/46 tires vs. old 38. in reply to TimFL, 08-06-2004 08:41:38
All set with 16" x 38" rims and centers for M-M hubs. Just need the tires. Hoping guys bumping up from 38" to larger would be selling their old 38" tires.
TimFL
08-06-2004 10:51:42
 Re: New tall 42/46 tires vs. old 38. in reply to Mopower, 08-06-2004 10:22:14
Good luck! Taller tires will gain you more traction and better flotation. Especially if you can luck out and get some radials. Only difficulty is probably most people aren't changing until the old tires are wore out.
