Tractor Talk Discussion Forum
Small colorado hay ranch in need of an articulatin
DJ Ranch
08-17-2004 12:40:05
Looking for advice on buying a tractor. I have been trying to find an owner or a person who has a Ford 276 or similar to determine if this is the tractor for me, or what might be better. I have 400 acres of high mountain meadow ground with really good hay but a few wet spots here and there.
Considerations: I need the loader, a rotary cutter, Round bailer and a hurricane style rake.
If you know of someone who has any of this equipment for sale or advice please respond.
DJ
DJ Ranch
08-17-2004 14:35:08
 seeking info/ knowledge on articulating 4wd Tracto in reply to DJ Ranch, 08-17-2004 12:40:05
What are the pros and cons of articulating tractors,wher should I shop for one used. You don"t fiond many for sale used, is it because there so good nobody wants to part with them? Who makes the most reliable model 1985 or better, avalability of part, breakdown history, availability of parts, ease of service any thing you might be able to help me with.
Lowell Chesborough
05-21-2005 06:08:38
 Re: seeking info/ knowledge on articulating 4wd Tr in reply to DJ Ranch, 08-17-2004 14:35:08
I realize that this reply is much too late to help the original poster: but for anyone else who happens to read the thread and is intersted in locating larger tractors, try:
ironsearch.com.
Adam B.
08-18-2004 22:55:18
Most articulated tractors you'll find are going to be very large machines built primarily for heavy tillage and large scale planting. If you're going to be making hay with the tractor in the 1985 and newer range, you should be able to find a row-crop tractor with MFWD in your power and price range very easily. Finding one with a loader or adding a loader to it shouldn't be a problem at all.
For service and parts availability, find out the closest, best dealer and at least consider whatever brand that dealer sells and services unless you're dead-set against that particular brand.
Articulated tractors handle quite differently than tractors with steer wheels, so you'll have to adapt to that.
My dad had a Steiger Panther II for tillage, and traded it for a John Deere 4850 with MFWD in the mid-80's. One of our fields is notorious for having a huge wet spot during the Spring that is all dried up by Fall. The Steiger always would get swamped in that wet spot, so that big portion of the field would usually not get worked up and planted. The first year he used the 4850, he pulled the same 24' disk through the wet spot with no trouble. We found the big MFWD tractors could tread through a lot of places the Steigers (grandpa also had a Steiger, a Turbo Tiger) would often get stuck in. The farm currently has that same 4850, which has been joined by a 4755 and two 4955's. I realize you don't need anything that large, but a MFWD tractor with a loader should handle your job.
If your heart is set on one of those bi-directional Versatile/Ford/New Holland tractors, you can use a search engine like HotBot or Google to track down equipment locator sites that will let you search for one. The major tractor manufacturers have used tractor search engines on their websites too.
2x4
08-17-2004 21:17:04
I own a New Holland TV140, which descended from the Versatile 276 to Ford 276 to Ford NH 9030 to tv140, now the tv145, recently sold off by NH. They are a very rare tractor, very seldom sold at auction. just got mine so I dont have history but they are built like a tank. Used mostly in Canada & western states. I bot it for the reputation for durability. For prices, go to the NH site & check used equipt. & see what dealers are asking. Ritchie Bros. just auctioned off 2 276's in Canada. Go to their site & ck. Ford tractor auction results.
