Tractor Talk Discussion Forum
O.T. Calling all Powerstroke owners with ZF 6 spd
Kevin (FL)
08-19-2004 09:23:06
Looking for any advice on clutch issues with the F350 Powerstroke with the 6 speed tranny. We have a 2001 SRW/4WD and have noticed clutch slippage under heavy towing, especially in the mountains. We don't have the dual mass flywheel but the OEM clutch isn't handling the load of a large gooseneck. (Our old chevy would either stall the engine or burn rubber but the clutch never slipped until it had over 250K miles on it.) Has anyone else had this same problem? Is the clutch covered under the warranty? And has anyone tried the LUK setup or any other make? How much time is involved in the change-out? Any inputs or suggestions would be appreciated. We just got back from a long trip and won't hit the road again until this is straightened out.
Roy B
08-20-2004 18:01:40
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Kevin (FL), 08-19-2004 09:23:06
Kevin
I have a "00 F350 PS 6 speed no problems here in 160 k. Travel trailer, horse trailer and goose neck for the tractors = lots of towing miles, no clutch issues. I put 280k on the dual mass system in my 93 turbo with no problems. I can't understand why anyone would want to tow with an auto. My $0.02 Roy
TheRealRon
08-20-2004 07:13:38
OK, I'll bite. Why on earth would anyone buy an HD truck for towing and then spec a manual transmission? Automatics are far more reliable. As long as you run a proper cooler and synthetic ATF they last the life of the truck with just a few filter changes.
Of course, in order to get a decent AT that means the Allison and a Duramax... maybe it's a Ford vs. Chevy thing.
Kevin (FL)
08-20-2004 15:12:23
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to TheRealRon, 08-20-2004 07:13:38
My reason for ordering the standard 6 speed was twofold--1. I can repair a standard transmission--can't repair an automatic. 2. ZF standard was over $1000 cheaper on the order sheet than the automatic. (At the time, it never occured to me that Ford's design folks missed the ball on the clutch's capacity to handle the torque of the engine it was connected to.)
I've spoken to several PS owners while fueling at truck stops and most that are pulling heavy goosenecks are saying that the autos require overhauls in less than 200K miles. Thats not to say that my next truck won't have an auto. Now if Allison would build a 6 speed auto....
Vern-MI
08-20-2004 16:33:17
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Kevin (FL), 08-20-2004 15:12:23
Diesel engine firing torsionals are much higher than gas firing torsionals. Every time the engine fires the clutch damper takes a hit and eventually the damper springs wear out and break. When the springs in the damper are gone the diesel firing torsionals get through to the clutch and cause it to at first just slip a little during each engine firing. After a bit of this minor slipping the clutch begins to wear and slip more and more until wears and overheats and is eventually destroyed.
Ford now has a 5R110W which is rated at 1100 ft.lbs. but it is the first offering so we will have to see what happens. Some of the earlier E4OD and 4R100 automatics with a converter clutch in the diesel applications got the converter cover so hot that it turned blue. That's hot and really working the lockup damper to maximum!
Don't know about the Zed F manual stuff.
Shane
08-20-2004 10:54:32
Auto's are more reliable than a manual? I would have to disagree totally hare. Why do most large trucks have manual trannys then? Even in a pickup I think a manual will outlast an auto more often than not. But like said before the clutch is the wear item and it may not last as long as the tranny itself or as long as an auto either.
TheRealRon
08-20-2004 11:35:56
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Shane, 08-20-2004 10:54:32
The transmissions used behind high torque light truck engines are about 95% ATs. The primary reason is clutches. MT's eat clutches like crazy. AT's have far more clutch surface to distribute the load over and are shifted by a computer which is far better at clutch pack management than any human being operating a foot clutch. When pulling very heavy loads, ATs clutches far outlast foot clutches.
The secondary reason is that AT's also have torque converters which at least double the available torque from a standing start... perfect for towing.
Your point about large trucks might have been true 20-30 years ago but today AT's are even used in off-highway construction equipment. Allison makes them and they are rated for over 4,000 lb. ft. of torque!
Allan in NE
08-20-2004 12:14:49
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to TheRealRon, 08-20-2004 11:35:56
Gotta agree with Ron on this one.
Automatics far, far, far and away outperform standard transmissions/clutch set ups for light-duty over the road applications.
Allan
Robert in W. Mi.
08-20-2004 17:15:08
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Allan in NE, 08-20-2004 12:14:49
I bought (2) 3/4 ton "diesel pu's", (new) with the same engine, but ones an auto tranny the other is a manual tranny. I have been useing both for pulling loads, sometimes quite heavy loads.
At 90,000 miles the auto went out, big bucks for a rebuild, as i couldn't do it my self!!!
At 180,000 miles i replaced the clutch on the manual tranny pu, and it still wasn't slipping or acting up. I replaced it because i was going to pull a big load 4,500 miles over the ALCAN hiway, and didn't want to take a chance on haveing a problem on that road. Best part is, i did it my self, and it wasn't all that expensive. This pu now has 199,200 miles on it, and the tranny is still origional. Infact, i just got back from pulling a load with it, 800 miles.
BTW, the auto has a big Haden tranny oil cooler, and was kept serviced!!!
Two weeks ago my Caprice Classics auto tranny started slipping. It also has a tranny cooler, and also has been kept serviced. It has 158,000 miles on it. It's never been abused or pulled any kind of a load!
Learn how to use, instead of "abuse" a clutch, and it will easily out last an auto tranny!!
Robert
T_Bone
08-19-2004 21:23:55
Hi Kevin,
Fords test for a bad/good clutch is to cholk the wheels, put in 4th gear (Fords 4th gear, 5th gear to the real world), let clutch out at idle:
If the the engine dies the clutch is good.
If the engine stays running the clutch is bad.
Ford has a known problem with early 2001 and before clutch disc (bad springs) and the pilot bushing. 99 had the bad clutch fork.
Late 2001 and on Ford chaged the clutch disc and so far I haven"t read of any early failures. Mine only has 16k miles so it"s too early.
I would do some research as the last time I checked (last year) SouthBend Clutch was a higher rated clutch than the LUK.
The SouthBend was rated close too 1000ft/lbs of torque in normal use. It was built on the paddle design like the clutch used in the semi"s. Serval options available.
I stumbled onto another website (sorry no bookmark) that RockFord ? Rockwell? that claimed a very high torque rating, exceed the SouthBend torque rating. Website had to do with the Eaton gear box add on units, and listed one for the Ford 7.3 PSD.
T_Bone
Kevin (FL)
08-20-2004 06:44:19
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to T_Bone, 08-19-2004 21:23:55
Thanks T-Bone--I found the South Bend site last night and I liked what I saw. Will check the other source too. If Ford doesn't do anything about the problem, I'll go afermarket and try to collect costs through my brother the lawyer....
T_Bone
08-20-2004 13:43:24
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Kevin (FL), 08-20-2004 06:44:19
Hi Kevin,
I think you said you quit driving your truck until it can be checked. Thats a real good idea as some of the guys are having the input shaft wiped out from the springs coming out of the disc and also takes out the pilot bushing. That seams to happen even if you catch it early.
Goto thedieselstop.com and do a search for user named Pat Dolan and read up on his clutch problems. He"s a commerical carrier with a F550 and has lost 3 or 4 clutchs. I think he gave up on the LUK clutch as it didn"t prove strong enough. I think his currnt clutch is a SB.
Rumor has it that LUK built the clutch for the late 2001 and up for Fords. I don"t know what build date they started with. I don"t think the exact month was known. It seams like it was June 01 as my 02 build date was 8/01 and it already had the updated clutch.
You might also see if the is a TSB or Oassis notice for the clutch. I haven"t seen one but I haven"t been keeping up with them like I need too. My bookmarks got a worm and I had to delete them and lost a ton of info.
T_Bone
Shane
08-20-2004 06:35:42
I live right here in South Bend and can tell you that those clutches are awesome. Neighbor put one in his 1 ton Chevy with some stout engine mods and it is still going after 100k pulling a 300 bushel gooseneck trailer. A lot of the local truck shops install the South Bend Clutches in the trucks they work on if the warranty is out.
Kevin (FL)
08-20-2004 07:00:31
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Shane, 08-20-2004 06:35:42
Thanks Shane--I'm leaning that way if Ford doesn't help out. We pulled a John Deere tractor through South Bend on the way to the AC show in Michigan ('03). Stopped in Orleans, Indiana for lunch. That highway 7 was "interesting" coming up from south of Indy--lots of steep hills and tight turns. (I think it was 7--we were coming up from Kentucky and it looked like a good route on the map. Didn't know there were mountains in Indiana. Always thought it was a flatland for growing corn...
Shane
08-20-2004 10:48:38
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Kevin (FL), 08-20-2004 07:00:31
Ha! Not flat at all around Terre Haute, just south and west of Indy. Pretty flat in most parts but it does get nasty here and there. I think SB Clutch is actually in Mishawaka which is SB's sister city and they kinda all run together. Sounds like you travel all over the country side.
Kevin (FL)
08-20-2004 15:03:14
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Shane, 08-20-2004 10:48:38
Several trips around the country--longest out to Idaho and returning through South Dakota and then down to Kentucky and back home to the FL panhandle. Made several up to Illinois/Wisconsin/Michigan and then across IN/OH/PA and then back down south. Learning I-80 pretty well. Also have made several trips to Texas/Louisiana. I have a much better appreciation for what truck drivers have to go through with the rude drivers and long hours and only being able to eat where you can park a 36' trailer...Not complaining--it's hard work but to go rescue an old tractor or bring one to someone else--it's worth the effort. Also, my 12-year old son is learning things he'll never learn in school.
Johnski
08-19-2004 14:40:56
Try www.dialaclutch.com these guys should have the answer to your problems. I haven't dealt with them myself but a buddy recommended them. He had a 98 F-350 that was nothing but trouble untl he got one of their clutch setups. HTH :)
Farmall_puller
08-19-2004 13:01:30
We have had 2 of these trucks, and all our buddies we pull with have one, they are hard on a clutch if you pull a trailer quite often, these trucks have alot of torque, thats why ur chevy never smoked a clutch, when u get a truck with that much power and good drivetrain something has to give, and the clutch is the weakest point, my suggestion is just find the best clutch u can find and if u pull a trailer a whole lot u may have to put it in about every 100 thousand, we have one right now that is at 90 thousand, and it is gonna need one b4 too awful long
Jim.UT
08-19-2004 12:32:35
You might also try Ford-Trucks.com. They have several discussion forums for different ages and styles of Ford truck.
John M
08-19-2004 12:11:46
Your clutch IS NOT covered under the 100000 mile warranty.but would be on the 36000 mile warranty.Only the engine is covered by 100000 mile warranty.
Allan in NE
08-19-2004 10:56:56
Hi Kevin,
I was a service manager at a Ford dealership for 4 years and can tell you that Ford is nortorious for two things: Bad electric fuel pumps and bad clutches.
However, are you really sure it is slipping? Are you sure you aren't just hearing that fan clutch coming in and out?
Never heard of one actually "slipping" before and anyway, this would leave you walking in a very short order if it was actually slipping. You would "smell" it too.
Usually, their clutches either pull or they don't and the problem usually lies in the hydraulic release/apply of the things.
They have some problems with the dual mass flywheels, but these are, again, usually balance related.
Allan
Kevin (FL)
08-19-2004 18:48:31
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Allan in NE, 08-19-2004 10:56:56
Allan,
It's definitely slipping. If I wanted to I could redline the engine speed by applying a little throttle--doesn't have to be coming up a hill. I barely made it home last night on the flatlands of the FL panhandle. Leaving a light, I had to go real easy on the throttle to prevent slippage. Even starting out in low, it will slip if I don't go real slow. Can't smell any burning though. This weekend I'll pull the cover off to see if there's any evidence of damage. I know what you mean about the fan roar--heard that coming down I-81 in the mountains. First time I heard it I thought it was the clutch but noticed right away that engine speed and road speed hadn't changed.
At about 40K miles I had to change the clutch cylinder assembly. Truck left me high and dry in Mississippi--pedal on the floor, no clutch release.
I mentioned my suspicions of clutch slippage to the dealer at about 30,000 miles but they said it wasn't slipping. Without having the trailer at the time, I couldn't demonstrate that it was a problem.
On the dual mass flywheel issue, I've been told by several folks that these were dropped by Ford well before 2001--I think in '99 or early 2000 or so. Also this truck was ordered in late 2001.
Since you worked for Ford can you tell me if the clutch is included in the powertrain warranty? I pretty much figured they won't back this up and I'll be buying and installing a LUK kit or something else if there's anything better out there.
Allan in NE
08-20-2004 05:37:19
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Kevin (FL), 08-19-2004 18:48:31
Hi Kevin,
I wouldn't go to the bother of pulling the inspection cover; doubt if you could see any evidence anyway.
From what you say, it sounds as though that truck needs to come down. If you were concerned about getting home last night, then it is probably on it's last leg for sure; something is definitely wrong.
About the warranty; I’ll try to give you some idea of how Ford thinks (this is from my experience) and this is all going to come down to how well you get along with that dealer.
Clutches and brakes are a touchy issue with any manufacturer, as they are a "wearable" & oftentimes an “abused” item. I. E. That gooseneck trailer you have hooked to the back of your truck. :>)
Clutches are warranted for the first 12,000 miles; most dealers will cover to 36K just to keep the customer happy. So legally, Ford really does not have to warranty that clutch.
However, on a diesel, the flywheel is considered part of the engine and it is warranted to 100K if it fails.
So, if that service manager has his hat on right, he will write the service order up in such a way that the flywheel is showing as the "failing" part & the rest of the clutch parts are failing incidental to that original 'failing' part. It could conceivably be done. (Do you notice that I’m trying to be somewhat ‘careful’ here?) :>)
Another point in your favor: Ford does not want to lose you as a repeat customer. It has been my experience that Ford will bend over backwards to get along with you, keep you happy and keep you coming back for your next vehicle purchases.
Now on the other hand, if you should go to after market parts for anything (repeat, ANYTHING); you've just written your own set of divorce papers; from that point on, you are outside the loop as far as Ford sees it and you are totally on your own.
For instance, Ford doesn't feel that they should warranty the left front brake caliper if you are pushing it via an after market fuel chip. This wasn't the way it was originally designed, and they want no part of it. What they are saying in effect, is that they do not warranty their product with someone else’s spoon stirring the soup.
If I were you, and if you have less than 100K miles on your truck, I would go have a cup of coffee and a heart to heart talk with your dealer; because I’m bettin’ he will take care of you.
Hope this helps and sure hope you get 'er going ‘cause you have tractors to haul!
Allan
Kevin (FL)
08-20-2004 06:40:31
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Allan in NE, 08-20-2004 05:37:19
Thanks Allan--some good words of advice. And I appreciate your time and efforts. I'll get up with the dealer next week. (Trailer still connected to the truck)--haven't had time to unload 3 sets of wheel weights, Farmall 140, AC diesel engine and hydraulic transmission, radiators, etc., etc.
Allan in NE
08-20-2004 06:45:37
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Kevin (FL), 08-20-2004 06:40:31
Kevin,
Not a problem..... just find me a clean IH 966 without a cab..... okay? :>)
Later
Kevin (FL)
08-20-2004 07:04:21
 Re: O.T. Calling all Powerstroke owners with ZF 6 in reply to Allan in NE, 08-20-2004 06:45:37
I'll keep my eyes peeled along the road. First though, I'll have to get a good clutch before I could carry that one onboard....
Burrhead
08-19-2004 16:36:58
You're right about that, usually they either pull or don't pull for me too. I have never had one to slip.
I've had 4 go out thru the years on these but mine is always the pressure plate that gives up.
Dan in Wisconsin
08-19-2004 10:40:23
f you don't find what you need here, try dieselstop.com. Pretty informative bunch and mostly deal with Ford diesels.
kraigWY
08-19-2004 10:06:18
I had to replace the clutch on my F250 power stroke, not sure of the brand I got it at Car Quest, It was $750 for the whole set up. Not much of a problem putting it in, Normal clutch job. I have heard since that the original ford clutch was defective. The 6sp tranny is ok but you may also have problems with your transfer case, the main drive rod needs oil holes drilled thru it. A modification recomended by ford. Cheaper to do it before the tranny blows up ( like it did for me). I would check into it if you are going to do a clutch job anyway.
