Tractor Talk Discussion Forum
How much in wagon can be safely pulled?
pbutler
08-23-2004 09:05:51
Does anyone know of a general rule of thumb as to how much you can safely pull-talking about wagons going to local elevator?
I have 1 large tractor (JD 4630) and 1 small (Massey 255) and 3 wagons-1 wagon is 300bu, 2 are 225 bu and am trying to figure out the best-and safe-way for this fall.
Thanks
Paul Butler
Leland
08-24-2004 13:49:41
 Re: How much in wagon can be safely pulled? in reply to pbutler, 08-23-2004 09:05:51
What you also need to worry about is state police you are only allowed #20000 per axle on wagons.In ILL they set up scales at eleavator drives. and some tickets run 3 GRAND a piece with a 4630 you should safly pull 2 or 3 wagons with no problems. I used to do it with a 706 and a 806 no problems just take your time and coast up to stop signs.
Bob NEIL
08-24-2004 07:27:22
1.) Install a 7-pin outlet on the back of the 4630, wired into the light and flasher circuit. Then you can use magnetic base flashers on the wagons.
2.) Don't forget to have safety chains in place between tractor and wagon or between wagons in case the hitch pin or king pin on the wagon breaks loose.
Assume the worst that can happen, and be prepared for it, especially if you are driving into town. If this is your first time driving into town, make a dry run empty, so you get a feel for sight lines, stopping points, turns, etc.
Jonathan
08-23-2004 20:21:21
No doubt heavy loads need to be thought through before attemped. I have no idea what grain weighs per bushel because I'm not in grain country, but I have pulled heavy loads before, in the form of liquid manure. I worked for a farmer who had a 5,000 gallon spreader and used an Allis Chalmers 7040 2wd to pull it with duels and no weights. If it wasn't for the spreader brakes, I'd say no way it wasn't safe, but with those brakes there to stop the load if something happens (the brakes are operated off 1 remote on the tractor), it was all right. now that spreader was all that 7040 wanted and I found myself having to help steer it with the tractor brakes often with a full load because the front wheels of the tractor would just skid when turned, and the clutch had to be released real easy unless you wanted a view of the sky. I learned quite a bit operating that rig, and one of them was why it isn't a good idea to go down a slick mud covered hillside with a full load on (I jacknifed it at the bottom) You had to use your head to stay out of trouble and those brakes made all the difference between safe and not. I then started working for the neighbors and their kid wondered why brakes were even put on spreaders, after all they had the exact same spreader without brakes and a much bigger 4wd with duels tractor to pull it. Another thing I learned it to go slow and take it easy and your much better off.
Hugh MacKay
08-23-2004 19:47:54
pbutler: I saw a guy heading for an elevator one day with a 200hp, 4x4 Deere, with duals, and pulling a set of highway B trains. He had a unit to operate the air brakes. Those trailers will hold 40 ton of grain. The countryside he was in is flat as your floor. I don't know the guy but am told he uses this tractor and the tandem axle dolly for taking individual trailers right to the combine. Normally it never sees the highway.
As most of the others said, this is not about what you can pull, but rather what you can safely stop.
john d
08-23-2004 18:37:49
The problem isn't what you can safely pull, it's what you can safely stop! Several years ago with the pressure of too much to do and not enough time, I pulled three wagons loaded with approximately 700 bushels of corn with a neighbor's Farmall H. Only had a short distance to go, and I had a short down-grade to get it rolling. The H (I never saw a more agressive H used in farm work) got it moving in low gear. Feeling pretty good, I shifted to 2nd. When I hit the road and got it straight, I went for 3rd. Rear wheels slipped a bit, but it wound up to full throttle. At that point, I felt giddy enough to move to 4th! The H surprised me, and within a few yards I had the whole train moving at about 5 mph. When I got to my driveway and turned in, I found stopping was a bit of a challenge. Getting that thing to a dead stop took ALL the room I had. Thinking about it later, I was glad I didn't have to make an emergency stop on the road.
Joe Evans
08-24-2004 05:59:05
 Re: How much in wagon can be safely pulled? in reply to john d, 08-23-2004 18:37:49
Amen to you. I saw this thread yesterday, but didn't get around to chipping in. You said EXACTLY what I was going to say. To me, pulling a big load was never that big of deal. Getting it stopped always made be a bit jerky. Think about it: you're asking a (two-wheel drive) tractor to hold back a load when the the drives are un-weighted, and the tires treads are asked to grip in the direction they were not designed to do.
We started farming with a too-light-in-the-butt Ford 9N. There were times when the little Ford went a-skatin' down a snotty grade with a load. I've also had similar experiences with Ferguson 35s and a Ferguson 202. Using these tractors with marginal downhill hold-back ability during my formative years was good training and experience albeit a bit risky.
I remember when I was 12 years old, Dad and I were helpng a neighbor make hay. We had two very full wagon loads ready to take back to the neighbor's barn--a trip of about 3 miles. I was told to get the neighbor's Ferguson 35 Diesel (how I loved that little tractor!) hooked up to one wagon. The neighbor was pondering hooking up two wagons to me, but was hesitant about doing that because of the size of the 35, me being only 12. Dad told him to "hitch 'em up. He'll get 'em there!"
Off I went. The 35's Perkins mill was up to the task. I had a couple of hills (on a paved road) to negotiate, but the little 35 hammered up them no problem using second-hi on the gear selection.
When I got to the neighbor's drive, I got real nervous about what lay before me: I had forgotten this drive was downhill, narrow and covered with gravel. Well, using the lessons Dad beat into my head, I geared down to first-hi, eased off the throttle and absolutely stayed off the brakes. The wagons pushed the little Ferguson a bit on the marbley stones, but I made it to port with little problem. Keep the drive wheels turning forward is the key.
paul
08-23-2004 13:25:44
Most locations only 2 hitches are allowed on the public roads - 2 wagons max.
Bigger or newer wagons are required to have hyd brakes, so your JD can handle anything it can get moving. See folks in my hilly area come in with 2 600bu wagons behind a similar sized front wheel assist tractor all the time.
I assume you do not have brakes on the wagons. Your JD would be able to handle any pair 'here' just fine, assuming your brakes are working.
The little tractor can handle one of the smaller wagons.
Now, if you have a _good_ wagon running gear, I would hook up one smaller wagon to the little tractor, and the other smaller wagon, followed by the bigger wagon, to the JD.
There is _some_ danger of jackknifing the small wagon in a sandwich between your tractor & the big wagon, but your sizes are fairly close so this _should_ work for you. But do consider the jacknife issue & proceed with caution.
The advantage of putting the slightly smaller wagon first is you can still see the rear wagon as well, watch for whipping or flat tires etc.
Always fill the front wogon first, you don't want a light empty front wagon with a full heavy one behind... Again, for wagons 50% difference in size or so, then you _must_ put the big one next to the tractor, the little one at the end. But it is hard to know what that hind little wagon is doing.
--->Paul
T_Bone
08-23-2004 19:37:28
 Re: How much in wagon can be safely pulled? in reply to paul, 08-23-2004 13:25:44
Hi Pbutler,
I got to agree with Paul as he"s given sound advice. Were not talking OTR trucking where were running posted speed but under 20mph slow speed pulling. There"s a huge difference!
I haul 20,000lbs of water trailer with my 8000lb pick-up at 15mph on sand roads and I"m well with-in my GVWR. I also pull a 13000lb RV at road speed (75mph) and I"m with-in my GVWR.
99% of the time I never touch a brake unless I come to a complete stop and thats with making several 90º corners with no brakes on the water trailer. Why? I use gears and engine RPM to control and slow down the load and only use the brakes for a complete stop.
I"ve always used the rule for trailers without brakes, what ever gear you can start from a dead stop in, is the highest gear you can safely pull that load. This allows the engine RPM and gearing to control the trailer load.
I also did some research on Arizona DOT rules awhile back and to be legal, my tractor needs turn signals and stop/tail lites after dark, and my water trailer needs two brake axles, one at over 3000lbs and two at over 6000lbs.
No where do they mention anything about a slow speed triangle but yet the local county mounty reconizes the tri-angle as a proper replacement for trailer lites.
T_Bone
G-MAN
08-23-2004 16:53:20
Two 600-bushel wagons behind one 4630-size MFWD tractor? That's insanity in my book, particularly in a hilly area. 75,000+ lbs rolling on eight tires behind a 20,000 lb tractor. Brakes or no brakes, that should be illegal, particularly when a semi with brakes on every axle and 18 wheels to carry the load can't gross anywhere near that much total weight. I also wonder about the reliability and capability of those built-in brake systems. Do they self-adjust or is the operator supposed to adjust them periodically? If they don't self-adjust, I can just imagine how many guys are running around with useless brakes on big wagons. Some people can't distinguish between "can" and "should", I guess. And FYI, the lawyers have now discovered farmers and the potential cash cow they represent when it comes to suing for damages. At a service school I went to last year they were telling us about a farmer that was driving down the road in his 4440 and was rear-ended by a kid in a Mustang. Nobody was killed, but the kid's family sued. Had he had a good SMV emblem on the tractor, he would have been blameless. Instead he had an old faded-out one, and it cost his insurance company a pretty penny, because he was "in the wrong". Just something to think about.
paul
08-23-2004 19:45:18
 Re: How much in wagon can be safely pulled? in reply to G-MAN, 08-23-2004 16:53:20
A couple of guys come in with their pickups and a non-braked 400bu gravity box too. That one makes me pause & wonder.
I pull 200 bu with a pickup, but not on the big hills.
A tractor is a little different to me - it has a slow max speed, good engine braking, & so on. Not saying I would be compfortable with the 1200 bu deal, but it doesn't scare me as much as the 400 bu wobbling behind a pickup.
--->Paul
Les
08-23-2004 18:27:41
I agree with you about the load being too much for a tractor that size,but I think a five axle semi can gross out up around the 80,000# mark.
Shane
08-24-2004 06:13:39
 Re: How much in wagon can be safely pulled? in reply to Les, 08-23-2004 18:27:41
Actually here in IN an 18 wheeler can gross upto 10% over weight (80k means 88K) IF it is hauling off a farm, not sure if it has to have farm plates or if any truck can gross over.
720Deere
08-23-2004 18:10:39
I have to say I'm with G-Man on this one! I know a guy that pulls an 1000 bushel grain cart with a 4955 MFWD w/duals and he has all he wants. He won't let just any of his men run it and when at all possible, he pulls it with his 8970. Farmers tend to do some pretty crazy things.
I used to pull a 10 ton New Idea tandem manure spreader with a JD 620 once in a while. Stupid, but I survived. Three quarters of a load on relatively flat ground. I would say that the spreader out-weighed the 620 by a factor of at least three. I wouldn't attempt such a thing anymore. As G-Man stated, too much liability and juries ready to award just about any ridiculous amount.
Leland
08-25-2004 17:24:29
 Re: How much in wagon can be safely pulled? in reply to 720Deere, 08-23-2004 18:10:39
I hope that guy with a 1000 bushel cart does not get caught . In ILL they wrote a guy a ticket for the same thing about $5000 for being overloaded on a single axle, and a monster fine for the 6 10 ton bridges he crossed. In ILL you are allowed no more than 20000# on any wagon axle
G-MAN
08-24-2004 07:44:18
We pull a 600-bushel cart with a Deere 8450, and clear full, that's a load. It handles it comfortably, but we rarely if ever pull it down the road full. And that's with a big heavy 4wd with duals all around and brakes at all four corners.
G-MAN
08-23-2004 10:59:08
As a general rule of thumb, you don't want to be pulling anything heavier than the tractor weighs, although it's unavoidable at times. 300 bushels at around 60 lbs would be 18,000 lbs, plus whatever the wagon weighs (2500 lbs maybe?). So you're going to be at or around 20,000 lbs total. I don't know how big that MF is, but if it's smaller than a 4630. I don't think I'd want that much behind it. The 4630 should be able to handle it. Maybe haul the smaller wagons one at a time with the MF. I know there are guys that would probaby take off with both or even all three wagons behind one tractor, but I wouldn't be one of them. I guess I'd rather make two safe trips than one dangerous one, and I haven't seen the load of grain yet worth tipping over in the ditch. And make sure all your safety equipment such as flashers, SMV signs and so forth are working and in good shape.
pbutler
08-23-2004 11:45:32
 Re: How much in wagon can be safely pulled? in reply to G-MAN, 08-23-2004 10:59:08
Thanks! That gives me a good idea.
We don't have many hills but there are a couple small one.
The massey only weighs problably 7000 lb or so, so even one of the small wagons would be overdoing it. Maybe I will hook it to one of them and just not overload the wagon.
The 4630 is over #20,000 and has hydraulic brakes so the two wagons behind it don't worry me too much.
Yep, all lights working on all tractors and new SMV emblems on all wagons.
Thanks again!
Paul Butler
Shane
08-23-2004 16:10:22
 Re: How much in wagon can be safely pulled? in reply to pbutler, 08-23-2004 11:45:32
Do any of the wagons have brakes? If they do you could probably haul them with the MF and not have much to worry about unless you have a big hill and the brakes fail. No way do semi's weigh anywhere near the trailer they are pulling. Nor many pickups but brakes make all the difference.
G-MAN
08-23-2004 16:43:03
 Re: How much in wagon can be safely pulled? in reply to Shane, 08-23-2004 16:10:22
No, but a semi is a whole different ball game, and most guys running around with pickups and gooseneck trailers are exceeding their recommended GVWR by a bunch. Not terribly safe, but it happens. Of course a semi is different. You have brakes on every axle and a semi-trailer, not a full trailer as on a gravity wagon. The trailer is much more integral with the truck, and puts a lot of it's load on the semi tractor. Basically one big unit that can flex in the middle. A gravity wagon or other full-trailer running gear doesn't put any weight on the tractor's rear axle, so if you have to stop quickly, the wagon wants to pass you. More like steering two separate units that happen to be slightly connected down the road. And it's made even worse if the wagon doesn't trail well. I've been there and done that, and I wouldn't be caught dead with 20,000 lbs behind a 7000-lb tractor, particularly when there's a much larger and more powerful tractor around to be used. I haven't seen any gravity wagons with brakes, but I haven't been around any new ones. Perhaps the big ones do have them now. As far as the brakes and semis go, in a lot of cases, a fully-loaded truck can actually stop better than an empty one because the tires are forced into better contact with the road, which keeps them turning instead of allowing them to lock up fully and skid.
pbutler
08-23-2004 19:23:10
 Re: How much in wagon can be safely pulled? in reply to G-MAN, 08-23-2004 16:43:03
No, no brakes on these older wagons. They are in good shape and trail nicely.
I have seen some new 500 and 600 bu wagons with them but not my oldies.
lsnurse
11-06-2006 06:32:33
 Re: How much in wagon can be safely pulled? in reply to pbutler, 08-23-2004 19:23:10
I just have a tractor\hayride question.I had a hayride about 1 mo ago and had about 40 6th graders.We had 2 wagons hooked behind 1 big JD tractor[I don't know the exact size of tractor,but my uncle told me it was safe.]We went on totally flat land and everything went find and it felt "safe."However this last weekend a different uncle had a hayride with about 40 adults and 2 wagons hooked together behind a much smaller tractor and it didn't feel safe and rightfully so,because going down a hill on the road,the tractor rolled over.Luckily no one was hurt,but I was totally upset,because I didn't think it was safe to begin with.My question is "Is it safe to haul 2 wagons with kids and 1 tractor if the tractor is "big enough"and you go on flat terrain?
Mike M
08-23-2004 09:47:43
I'm sure it will all depend on how many hills you have to go up and down and how steep they are. You may get better and safer advice from talking to your neighbors and also seeing them do it.
