Tractor Talk Discussion Forum
Fiat Tractor 450-460 ???
Bryan
09-08-2004 16:33:46
Hi I just bought a fiat tractor and the seller said it was a 415, but the 415 has 4 cylinders and mine has 3 cylinders. The only numbers on the tractor are the numbers on the engine which are:
853A-100-0841753 which is stamped on the block
4602064-OM-B which is cast on the sump with
H2C20C
I have looked on the net for ages to try to find some information but with no luck. I'm also after a repair manual aswell so if anyone can help me out on this it will be greatly appreciated.
cheers Bryan
Jason Stone
01-14-2005 21:57:28
 Re: Fiat Tractor 450-460 ??? in reply to Bryan, 09-08-2004 16:33:46
I bought a fiat 415 too and having a hard time to but i took a wire brush to the motor and found the numbers 8035.02*304-109964 it had been painted over which is a fiat 450 or oliver 1250a
i need the manual too good luck
Manuel
09-09-2004 00:46:36
The 415 had the 138ci 4 cyl motor.
The 450 had the 142ci [95mm bore] & the 160 ci [100mm bore] 3 cyl motors.
Not sure about a 460.
Keep looking for a serial no on the tractor itself.
Hope this helps Manuel
