Tractor Talk Discussion Forum
Alternatives to CaCl in tires....
Jerry A.
09-14-2004 14:19:19
What are some alternatives to putting CaCl solution in the tires for ballast and traction? I've heard of windshield washer fluid and alcohol solutions (what kind?). Any thoughts?
I suppose used antifreeze would also work.
TimFL
09-14-2004 22:52:31
 Re: Alternatives to CaCl in tires.... in reply to Jerry A., 09-14-2004 14:19:19
Concrete, dirt, burnt oil, hot roofing tar, ground up recycled tires, corn syrup, molasses, liquid nitrogen not good alternatives?
Where are you at Jerry? Do you need an antifreeze product? Down here in Florida we use some really nasty, toxic stuff called well water. Slap a tube in the tire to protect the rim, get tubes for radial tires if you have em, hook up the water hose and fill er up. If you get good enough at it you dont even have to use the air compressor when your done. What I could never figure out is why you would go through the mess of dealing with CaCl for an extra 600 - 800 pounds on a tractor that already weighs 10,000 pounds. That is except for antifreeze purposes. And if your tractor uses 50 gallons of diesel a day you loose about 400 lbs of ballast as the day goes on. I think I will go to work on a tire heater that replaces the valve stem so you could just use water.
Does anyone know if a tire with 20 lbs of air weighs more than a flat tire?
Tims$.02
720Deere
09-15-2004 06:14:23
 Re: Alternatives to CaCl in tires.... in reply to TimFL, 09-14-2004 22:52:31
Technically speaking, diesel fuel weighs only about 7 lbs per gallon. Also, the fuel tank is usually located far enough forward that loss of fuel weight wouldn't much affect the weight on the rear wheels.
I'm with you on the water idea. Antifreeze is toxic and CaCl just plain sucks. I loaded my tires with plain old water this year and since I don't use the tractor in the winter months, I will drain the tires for winter storage. I realize that you can't drain 100% of the water out and will probably use a little non-toxic antifreeze to take care of that. Next year I will reload with water again and that little bit of non toxic antifreeze will be insignificant in 90 gallons of water. The process is just too easy vs. the hazards and cost of permanent solutions to freezing.
Another common misconception is that glycol antifreeze solutions are lighter than water. This is untrue! Ethylene Glycol has a specific gravity of 1.11 or 11% more than pure water. That would make a 50/50 mixture about 5.5% heavier than plain old water or about 8.79 lbs per gallon. That's still not heavier than CaCl, but definitely heavier than plain H20.
paul
09-14-2004 18:17:34
I do not like _any_ of your alternatives. They are toxic. Whil CC will leave brown grass, it is not toxic. Spilling 50 gal of antifreeze technically brings in the EPA on you....
Also, CC is heavier than water, while your antifreezes are lighter than water. Kinda defeats the purpose.
Then, my coop tire service place at least, would be royally ticked if I contaminated their CC supply fooling around with antifreeze in my tires. I think I'd have some liability on that.
There is at least one product made from beet pulp called Rim Guard that is designed to be a non-corosive tire fluid. I'd go with that if you don't want CC.
--->Paul
HTR
09-15-2004 17:31:11
 Re: Alternatives to CaCl in tires.... in reply to paul, 09-14-2004 18:17:34
The weight of H2o +CC depends on the strength of the solution. It is no problem to dissolve 400 hundred pounds of CC in a 55 gal. drum.
Dave 2N
09-14-2004 18:45:38
Can't believe anyone's tractor will notice the differnce between CaCl and windshield eaher fluid. Rims will notice the difference by not corroding. We get windshield waher fluid from Wal-Mart at about .$67 per gallon.
TheRealRon
09-14-2004 19:03:45
 Re: Alternatives to CaCl in tires.... in reply to Dave 2N, 09-14-2004 18:45:38
Yes you will. H2O + CaCl is 30-35% heavier than H2O alone and therefore about 40% heavier than wwf. You put stuff in you tires to make the heavier, that's the point.
Rims rust because people don't fix leaks. Salt water makes them rust faster but they rust just the same with pure water.
At $.67 per gallon you are paying at least twice what I pay for H2O + CaCl.
Shep VA
09-15-2004 07:53:57
 Re: Alternatives to CaCl in tires.... in reply to TheRealRon, 09-14-2004 19:03:45
Thanks Ron,
There is nothing wrong with CaCl, it works great and it is a lot heavier than water or anti-freeze. If you have problems with your rims, it is because you are not paying attention to your tires, period. We have 8 tractors on the farm with CaCl in the tires and have not had any problems with them. We also have a few that just have air in the tires, and it is a huge difference just trying to back haywagons up the barn bridge or other small tasks.
Bottom line is, you fix the leaks and wash the rims quickly, and you inspect your tires for signs of cracks or holes and replace them in a timely manner. It is just like a lot of other things on the farm, it will work fine "if" you manage it correctly. Abuse it and it will tear your rims and fenders off your tractors.
Little Ed
09-14-2004 20:01:21
Ron, where are you located? Salem Tire Center in Salem Illinois just quoted me a price of $3.oo per gallon for CaCl and $90 to come out and put it in. I have never bought any before and probably never will at that price
paul
09-15-2004 06:59:55
 Re: Alternatives to CaCl in tires.... in reply to Little Ed, 09-14-2004 20:01:21
Wow. I had a rear tire replaced on a 960, with tube, old CC pumped out, replaced in new tire, plus had CC put in the rears of a 1720 all on the same service call. Bill was around $300. For everything.
Can't imagine why you folks are getting gouged so much.
I'd sure by my own & do it myself for those prices.
Being as CC is 40% heavier than washer fluid, and you are trying to add weight, I don't follow the other argument that 'the tractor won't notice the difference' the other person made?
As to rust, living in Minnesota my rims rust out a _lot_ faster from the salted MN winter roads rather than any CC inside of them. You should see the gravity box rims. Even the boxes themselves rust from the wheel spray if you haul any grain in winter. CC is a minor concern. It is the right product for the job on so many levels.
--->Paul
TheRealRon
09-15-2004 03:56:38
You can buy 50 lb. bags of CaCl at your farm/feed store for under $20. You supply the water. Up here they charge $50 per tractor rear to mix and pump it. www.gemplers.com sells the adapters so you can do it yourself. They also have instructions on exactly how to do it.
Allan in NE
09-15-2004 03:34:12
Hi Guys,
The local tire shop charges me $1.50 a gallon, plus $1.25 a mile, plus $25.00 service charge.
Can't wait to get down outta these hills and get rid of the darned stuff.
'Course don't cha know, they are gonna charge me to haul the silly stuff off too.
Can't win. :>)
Allan
TheRealRon
09-15-2004 04:06:36
 Re: Alternatives to CaCl in tires.... in reply to Allan in NE, 09-15-2004 03:34:12
Allan,
Why do you want to farm? At those prices you should be in the calcium service business!
This is entirely up to you but if you want to get rid of it just dump it on a gravel driveway. CaCl is used in many parts of the country just like NaCl (salt) during the winter. It's not harmful to anything or anybody in the long term; in the short term it will kill plants so a driveway is safe.
Ron
steve-ny
09-14-2004 17:55:35
I got a new NH TN65 this spring,and the dealer loaded the tires with this stuff that is a by-product of making mollassis(sp?) looks like poop, but weighs 10.3# per gal. and does'nt freeze down to -40 F.
Tim in NB
09-14-2004 16:27:00
Up here, we have a product called Agri-lim 50. It is distributed by Provincial Bandag Tire Ltd here in New Brunswick. Non corrosive, non pollutant and biodegradable but it cost more than calcium.
Indydirtfarmer
09-14-2004 15:22:43
I've been using Methyl alcohol based windshield washer solution for years now. It's a bit lighter than CaCl, but when you consider that most tractor tires, once filled with fluid, are WAY too heavy to begin with, a few pounds aren't that important. I buy it from a supplier that serves gas stations. I get it in 55 gallon drums, for about $.60 a gallon. That ends up being cheaper than CaCl. It doesn't cause rust when I get one of those dozens of flats every summer. John
Allan in NE
09-14-2004 15:37:47
 Re: Alternatives to CaCl in tires.... in reply to Indydirtfarmer, 09-14-2004 15:22:43
Now John,
I was led to believe that you never had any trouble of any kind, no flats nor any break downs ever.
What's going on? Wassssa deal here? :>)
Allan
Indydirtfarmer
09-14-2004 15:55:01
 Re: Alternatives to CaCl in tires.... in reply to Allan in NE, 09-14-2004 15:37:47
We do about 400 hours worth of bush hogging a summer, for a couple commercial real estate brokers in the Louisville area. My son, or me one, is on a tractor just about every day. We hit bicycle frames, car rims, boards full of nails, concrete blocks, dead dogs, ect..... We end up with about 15 to 20 flats a year. Most are front tires, but so far this year, I've fixed 4 flat rear tires. I'm shopping for a new tractor for my son to run next year. (65 to 75 HP, cab w/ AC) We will foam-fill the tires....NO MORE FLATS! John
Leland
09-14-2004 20:56:46
 Re: Alternatives to CaCl in tires.... in reply to Indydirtfarmer, 09-14-2004 15:55:01
I hope you plan on trailering this tractor foam filled tires won't last long on pavment. Had a 544 deere with foam rode real rough and tires can't handle road speeds very well rubber breaks off, and the tires don't float anymore so plan on pulling him out of soft ground a lot.
TheRealRon
09-15-2004 05:31:54
 Re: Alternatives to CaCl in tires.... in reply to Leland, 09-14-2004 20:56:46
Good point. I use www.ultraseal.com in all my tires. www.gemplers.com sells it. The high-speed grade (trucks) seals to 1/4". The low-speed grade (tractors) seals to 1/2". It's standard equipment on military Humvees. It's saved me several times. Not cheap but cheaper than fixing flats.
Indydirtfarmer
09-15-2004 05:01:17
I don't do any bush hogging on paved roads. The tractor will be hauled everywhere, and with fluid in the tires, there isn't any flotation anyway, so that won't be any different. We run foam in one tractor now. It's worked out just fine. John
al boulais
09-14-2004 16:34:04
i use drain antifreeze most service stations are happy to get rid of it ten years never had a problem has rust inhibitors its free
JT
09-14-2004 16:57:37
 Re: Alternatives to CaCl in tires.... in reply to al boulais, 09-14-2004 16:34:04
and if you use antifreeze and the tires gets a leak, are you ready to accept the responsibility of ground water contamination, or the pets you could kill???? Antifreeze is a very dangerous product to use for this situation.
Ben in KY
09-15-2004 06:38:30
 Re: Alternatives to CaCl in tires.... in reply to JT, 09-14-2004 16:57:37
The new non toxic antifreeze seems to be about the same as using CaCl in my area. Figure at about 3.00/gal. $6.00 gal for the non toxic antifreeze mixed 50% = 3.00/gal. No rim rot either.
RickB
09-14-2004 14:52:00
There is a good, cost effective alternative to CaCL. Rim Guard, also sold as BallastStar, is a byproduct of sugar beet processing. It is nontoxic, noncorrosive, OSHA approved. Slush free to well below zero, and weighs 11lb/gal. Google Ballast Star for info. The dealer I work for has used this exclusively for almost three years, and most dealers in the area are now using it as well.
wdTom
09-14-2004 17:12:24
 Re: Alternatives to CaCl in tires.... in reply to RickB, 09-14-2004 14:52:00
RickB,
Can you give us an idea of the cost of Rim Guard?
TheRealRon
09-14-2004 14:47:35
There are none. CaCl is far heavier than water, providing exceptional weight as well as freeze protection.
Alcohol and windshield washer fluid are lighter than water and pricey. Used coolant is fatal in tiny doses to cats, dogs, and kids. If you had leak problems with CaCl you will have them with coolant too. Leaks are caused by poor maintenance, not the fluids.
In the south, they use beet juice. I always knew they were good for something... they sure are nasty to eat.
Or maybe you want to try this. Years ago I was in the plant that makes those tow tractors they use to yank 747's around at airports. Wonder how they get such great traction? The tires are filled with powdered lead!
Leland
09-14-2004 21:03:08
 Re: Alternatives to CaCl in tires.... in reply to TheRealRon, 09-14-2004 14:47:35
If you want to see a heavy tire find a tire full of foam, we had to use a boom truck just to remove one from a 544 deere wheel loader. with foam we had enough counter balance to lift 80 8ft railroad ties at full reach and rear never lifted 1 in and you could run as fast as you dare to go.
Sid
09-14-2004 18:30:18
"There are none." I beg to disagree with you on this one. You may personaly prefer CaCL to window washer fluid or alcohol. But they are alternatives to CaCl. You mentioned beet pulp and that is another alternative. I personaly thinks beets taste good so disagree with you on that as well. I have never heard of powdered lead being used in tires , but it seems to me that it would be an altternative. I wonder how it would be removed from the tube and handled to prevent contamination when changing or repairing tires. So it seems to me we have plenty of alternative choices to using CaCL in tires. Just my thought on the subject.
BrokenFences
09-14-2004 14:36:59
I prefer the anti freeze washer fluid or RV antifreeze, non toxic. Alcohol may get expensive.
