Tractor Talk Discussion Forum
Ford 2000 LCG conversion
Peter Fish
09-27-2004 07:19:31
I have dual rear wheels on a 1964 Ford 2000 LCG. One of the rims is starting to deteriorate. I would like to get larger wheels and tires to create some more ground clearance. Does anyone have experience with such a conversion? Any advice would be helpful.
dave1
09-28-2004 04:29:03
 Re: Ford 2000 LCG conversion in reply to Peter Fish, 09-27-2004 07:19:31
I have changed over a couple of these LCG's. As Rick states, the front spindles are shorter, but only by 1 1/2 inches. it is easy to change these out if desired, 8N all the way up to the 1000 series will fit. I have heard that the gearing is different, but to me, barely noticable. Low gear is still as low as you would ever need Dave
RickB
09-27-2004 15:50:22
Yes. The front spindles are shorter, so larger tires on front won't keep it from 'running downhill'. Faster final drive gearing on 3 cylinder LCG's make conversions go really fast. Not sure about your 4 cyl 1964, but I would find out before swapping.
