Tractor Talk Discussion Forum
How To:
Minn Norske
10-08-2004 06:33:35
Test coils to find out if they are any good !Thanks
Kendall
10-08-2004 12:07:59
 Re: How To: in reply to Minn Norske, 10-08-2004 06:33:35
Dont have any exact numbers but you should see something around 1-3 ohms between the neg and pos terminals and 8k -12k ohms or something really high, between the neg terminal and the center post where the hot stuff comes out.
JHesler
10-08-2004 10:15:43
Easiest way is to see what kind of spark they generate. Hook it up with batt terminal going to battery + and spark plug threads wired to battery -. Hold a wire between the coil - terminal and battery - for a second, then lift the wire. You should get a srtong blue spark. A further test would be to heat the coil up to about 250 degrees in the oven and try the test again.
