Tractor Talk Discussion Forum
Hook or Unhook?
Bill (KY)
10-13-2004 08:37:27
This is OT but I could not find a better place to post. Is there any reason to unhook a loaded gooseneck trailer from a pickup that is fully loaded but not overloaded for 3 - 5 days? I don't want to over stress the truck but it sure can be hard to jack back up on an "old" man if I unhook it. As I said, the truck isn't overloaded but I don't want to damage suspension or tires. Is that a concern or are they built to take the pressure? Thanks.
Oliver
10-13-2004 12:33:12
 Re: Hook or Unhook? in reply to Bill (KY) , 10-13-2004 08:37:27
That depends, is the truck a Ford?
chebby
10-13-2004 18:08:45
 Re: Hook or Unhook? in reply to Oliver, 10-13-2004 12:33:12
if so, on hook, rebuild motor, trans, new bearings, new frame. just be easier to get a chevy.
Rod F.
10-13-2004 19:08:56
 Re: Hook or Unhook? in reply to chebby, 10-13-2004 18:08:45
Course, if you have a chevy, you will need to unhook the trailer, to hitch it to your buddy's Ford, so he can haul your chevy to the dealer for every little problem.....
rustyfarmall
10-13-2004 09:27:56
Wouldn't be nearly as hard on the truck just sitting as it would with the same load running up and down the road. If it were mine I would just park it and not worry.
idontno
10-13-2004 08:55:19
No it won't hurt it to sit for a while.No it won't hurt to unhook it.But if you are concerned about the weight on your truck....Just roll your trailer jack down to take some weight off the truck..... But don't forget to raise it before you take off..... idontno
Mark - IN.
10-13-2004 19:10:48
 Just that simple. in reply to idontno, 10-13-2004 08:55:19
Probably the best answer that anyone will give. Satisfies both sides. Can only go wrong if forget to raise the jacks.
