Tractor Talk Discussion Forum
Kosch steering aid --what is it?
T.B.
11-27-2004 17:50:34
I bought a TO-30 with a Kosch steering aid on it. The steering wheel is in bad shape (bent up), but repairable if this Kosch steering aid is a good thing. Is it easy to replace?
billyiron
11-27-2004 19:32:21
 Re: Kosch steering aid --what is it? in reply to T.B., 11-27-2004 17:50:34
Grandpa has a kosch wheel on his 36 JD A it helps keep the front wheels from over powering the the guy doing the steering say if you were to hit a badger hole or the like,, I think theres some rollers in the steering wheel to prevent kickback,,I dont know if kosch makes repairs or not,,same guys that make kosch mowers I think,,maybe take it apart and clean it and it might work like new,,,,billyiron
Roy Suomi
11-27-2004 19:23:50
I got one that fits a 9-N. This steering aid uses roller bearings inside to " lock the wheel " when you drive across plow furrows without the wheel being ripped out of your hands. They work..When you steer after going over furrows this allows the rollers to go back into the "valleys" so it steers as it should..I want 300.00 for mine... It comes off easily. Take the wheel off. disassemble it. take the nut off existing steering shaft, Loosen screw at bottom ring , pull off..
T.B.
11-27-2004 21:42:08
 Re: Kosch steering aid --what is it? in reply to Roy Suomi, 11-27-2004 19:23:50
So it sounds like a keeper. I appreciate your time.
Thanks.
