Tractor Talk Discussion Forum
806 No power steering, no TA no Brakes
stxjdt
12-19-2004 19:37:00
I drove the tractor in to the shop to change the hydraulic filter. Changed the filter and started having problems. I now have no power steering no TA and no brakes. Checked the filter again, pulled MCV valve out, put oil in the pump and spun it with the drill and it would not push thumb off of the pressure side. Any ideas? Help!
twopop
12-20-2004 05:13:03
 Re: 806 No power steering, no TA no Brakes in reply to stxjdt, 12-19-2004 19:37:00
the check valve in the mcv may be leaking.reinstall the mcv and pressurize the main frame with air.then start engine.the air should force oil into the pump.
when you change the filter,the pump lost its prime
