Tractor Talk Discussion Forum
Hydraulics jump
DonD
01-03-2005 06:55:23
Hydraulics work well , not slow , Just they bounce . The tractor sat for a yr and I drained the fluid but it is still jumping ?
RWK in WI
01-03-2005 16:20:36
 Re: Hydraulics jump in reply to DonD, 01-03-2005 06:55:23
Depending on the temperatures where you are it could be some frozen condensation ( ice crystals ) moving through the system. If after working the system for a while and warming up the fluid it works better it might be time to check the fluid. If it is milky another drain and refill will be in order.
Mac
01-03-2005 14:46:51
Most often caused by 3pt lift cyl piston leak. Hitch senses drop and tries to maintain position. Put implement on 3pt, raise and see how long it takes to drop when tractor is shut down. If it drops before a few hours, most likely piston seals. Can be caused by hitch height adjustment off also I think.
NukemJack
01-03-2005 11:03:45
Sounds like the rings or seals in the hydraulic pump need to be replaced if you are asking about the lift arms bouncing as they are being raised or holding under some amount of load.
DonD
01-03-2005 11:30:15
 Re: Hydraulics jump in reply to NukemJack, 01-03-2005 11:03:45
it bounces without under load the 3-point more than the bucket they are all in one system
paul
01-03-2005 09:25:18
What tractor, and the 3pt specificlly hiccups, or all hydraulics are bouncy? Not sure what you mean exactly.
--->Paul
DonD
01-03-2005 11:28:48
 Re: Hydraulics jump in reply to paul, 01-03-2005 09:25:18
MF50 the 3-point jumps the most the bucket some under no load it can pick up and works just actually when bucket is empty and 3-point with blade goes up and down it will bounce the 3-point more than the bucket
ben uk
01-03-2005 09:10:06
make and model of tractor?
DonD
01-03-2005 11:31:40
 Re: Hydraulics jump in reply to ben uk, 01-03-2005 09:10:06
MF50 1963 all hydraulics are on one system 3-point and bucket it has trip bucket hydraulics raise and lower it is all the 3-point bounces more than bucket
old
01-03-2005 08:08:02
Most of the time that is caused by being low on fluid or air in the system. Make sure its full and then cycle it all the way on all cylinders a few times.
DonD
01-03-2005 11:33:04
 Re: Hydraulics jump in reply to old, 01-03-2005 08:08:02
ok ,,,,, ,,,,, hope that is all it is ..... it worked ok but then sat a yr. HOw would i get air out ? MF50 i have drained and added new fluid .
old
01-03-2005 11:55:34
 Re: Hydraulics jump in reply to DonD, 01-03-2005 11:33:04
All I ever do is cycle all cylinders a lot
