Tractor Talk Discussion Forum
Duals
Allan in NE
01-17-2005 17:16:49
Hi Guys,
Can a feller still buy these clamp on duals? Used to be able to buy 'em from Co-Op, without getting skinned up too darned bad.
Thanks,
Allan
third party image
Bill in Colo
01-18-2005 15:23:09
 Re: Duals in reply to Allan in NE, 01-17-2005 17:16:49
Can't do
Have 4 but still use them occasionally on my 2470 case they are stepup's from 20.8 x 34's
Vern in Iowa
01-18-2005 18:17:19
 Re: Duals in reply to Bill in Colo, 01-18-2005 15:23:09
Bil in Colo....I would be interested in your 18x30's. Our daughter lives in Fort Collins and will take a trip to see our grandkids and pick up your tires at a truck stop or some place, let me know. Email is open. Thanks
paul
01-18-2005 08:54:28
You must truely be in dry country if a set that close to the inner tire works, would be useless without some mud room between the tires around here.
--->Paul
JT
01-18-2005 13:27:18
 Re: Duals in reply to paul, 01-18-2005 08:54:28
Pulled an 18' field cultivator through a lot of old black gumbo here in Illinois, never had the madd ball up.
leland
01-18-2005 18:18:33
 Re: Duals in reply to JT, 01-18-2005 13:27:18
This happened in a field that had a creek rerouted always a few soggy spots and we had some ground you had to hit with a disk just so it would dry out before you could plant, had a lot of sand and clay like quick sand.
leland
01-18-2005 12:52:59
Paul even with hub mounted duals I have still ripped off valve stem on inside tire in mud with a foot gap between tires.
JT
01-18-2005 07:59:48
Allan,
got a good set of 18.4 X 38 clamp on duels of off a 1086. Dad sold tractor, Duals are still here. Do not have clamps that bolt to tractor, do have all the drawbolts. Tires are in good shape probably 60-70% tread left. Can get pictures if you wnat. The only drawback, they are in Central Illinois. He wants $250.00 for them, tires are worth more than that.
Jim
Allan in NE
01-18-2005 09:08:08
 Re: Duals in reply to JT, 01-18-2005 07:59:48
Hi Jim,
My email is uncovered. Could we talk?
Thanks,
Allan
JMS/MN
01-17-2005 22:47:38
I haven't seen clamp on duals for many years, but the mounting system was never a big deal- the clamp might be a bit quicker, tho. I would not mount duals so close to the inside tire- they just ball up with mud after the first low spot. I made straddle duals for my planter tractor and combine- so they center between the rows, don't pack the row, and stay clean in the mud. With all duals, whether front tractor wheel or rear, or combine, I weld rings on the J-bolts, and tie the bolts together with a light chain, so if one comes loose, it does not get lost. Years ago I planted with a 3020, no cab, and could hear if one was loose, but with cab tractors I couldn't hear that, so now I don't lose any bolts. I make rings out of old field cultivator springs, cut lengthwise with the chopsaw.
Can't even use my name
01-18-2005 09:05:47
 Re: Duals in reply to JMS/MN, 01-17-2005 22:47:38
Here's another idea. Drill a hole in the end of the J that goes through the clamp and insert a cotter key or lynch clip.
Migraine
01-17-2005 21:25:46
Allen, ever tried to take off a set of those after packed full of mud and cow or hog biosolids(or whatever stage yours was in)? If you did it once you go to town and get those 9 bolt axle hubs so fast that mama hardly has time to wash off the remains. I've got a set of 12 by 38 rims ready to go for ya I'll put a big "A" on the bucket full of clamps tomorrow. Migraine
Allan in NE
01-18-2005 04:14:33
 Re: Duals in reply to Migraine, 01-17-2005 21:25:46
Hi Migraine,
Oh sure, many times. I use the tractor to do it. A circle in each direction while tapping the brake. They'll jump right off of there. :>)
Allan
johndeeregene
01-17-2005 19:25:13
just start goin to the farm sales. you can pick them up pretty cheap. i bought a pair last year with good tires an clamps for 100
johndeeregene
Bill in Colo
01-17-2005 18:36:47
Allen,
I'll trade you a set of 18.4 X 30's for a steak dinner
Allan in NE
01-17-2005 18:42:12
 Re: Duals in reply to Bill in Colo, 01-17-2005 18:36:47
Would ya go 18.4 x 38? :>)
Allan
BurlGoat
01-17-2005 18:36:16
Durn Allan
You had me scared there when I seen your topic thought you were looking for dual pipes to put on your darn horseys.LOL.Hey tell your wife I have the perfect thing for her.I have a few jacka$$es at the farm I know she will tell you the same thing my wife tells me she already has one.
Have agood evening. Burlgoat
grazer
01-17-2005 17:33:30
We can buy these all over here in wisc.
JMS/MN
01-17-2005 22:52:44
 Re: Duals in reply to grazer, 01-17-2005 17:33:30
Two years ago at a neighbor's estate sale, 34, 38 inch duals went for $5 a wheel, tire and rim, no J-bolts. Guy was an auction jockey and at least two dozen wheels went unsold. $5 would have bought the whole lot. It was tempting!
steveormary
01-17-2005 19:21:54
Allan;
You could put a set of traks on it something like the bombadier traks they put on the little Fords. Is it warming up in your part of the world?
steveormary
