Tractor Talk Discussion Forum
CASE 830 HYDRAULIC FILTER
KGWATKINS
01-22-2005 09:51:02
CONFUSED. SO MANY LITTLE DOORS/PANELS ON TRACTOR.
CAN SOMEONE CUT TO THE CHASE AND TELL ME WHERE IN THE HECK THE HYDRAULIC FILTER IS ON THIS 830 DIESEL TRACTOR..... IT"S SNOWING BAD AND I AM TRYING TO FIND IT IN A HURRY.
ANY SUGGESTIONS WOULD HELP AT THIS POINT.
THANKS.
Roger H
01-22-2005 10:32:07
 Re: CASE 830 HYDRAULIC FILTER in reply to KGWATKINS, 01-22-2005 09:51:02
If your 830 is a Comfort King, the filter is a spin on type that is under the operators platform on the left side, the filter sticks straight out toward the rear tire. If it is not a Comfort King, look on the rear below the pto shaft, you are looking for a triangle shaped plate with 3 bolts in it. If it on the rear of the tractor, get ready to catch the oil in a pan when you loosen the bolts, don't take the bolts all the way out until the oil slows down or stops running out, this filter is what Case called an edge wound filter that can be cleaned & re-used. Good Luck..Roger
KGWATKINS
01-23-2005 05:21:11
 Re: CASE 830 HYDRAULIC FILTER in reply to Roger H, 01-22-2005 10:32:07
WHAT A LIVESAVER. THANKS A LOT.
MY FINGERS ABOUT FROZE OFF TRYING TO FIND THAT STUPID THING.
I REALLY APPRECIATE THE HELP.
Roger H
01-23-2005 06:55:52
 Re: CASE 830 HYDRAULIC FILTER in reply to KGWATKINS, 01-23-2005 05:21:11
Which one was it? the spin on or the washable type?
