Tractor Talk Discussion Forum
ford tractor
Antster
02-12-2005 17:47:34
need help figuring out if I have a 8n or 9n ford tractor. where do I start
Volz
02-14-2005 07:44:19
 Re: ford tractor in reply to Antster, 02-12-2005 17:47:34
I have a 9/8N It has an 8N motor/ front mount distributor a 4 speed transmission, steering, and gauges with a 9N front axel and rear.The engine numbers are 8N the rear is 9N. No one has come up with a designation for it. It works just fine however.
Wi Craig
02-13-2005 18:19:51
Might be a cross breed also. Lots of 2 Ns with 8n engines.
john in la
02-13-2005 00:33:27
mattd
02-12-2005 20:16:54
serial number is to the right of the oil filter. it is stamped into the block. and may be hard to read. but if it starts with 9n its a 9n or 2n. starts with 8n its an 8n. also what roy said.
matt
Roy Suomi
02-12-2005 17:57:44
9-N had a 3 speed transmission, 8-N had a 4 speed transmission..9-N had no draft control lever under the seat, 8-N had draft control lever.. Check engine serial number. That is machine number too.
