Tractor Talk Discussion Forum
3-wheeler tractors
heiko
03-13-2005 10:03:04
coming from germany, 3-wheel-tractors are quite a new experience to me.
we simply don"t have them here and never had as far as I know...
can anybody please explain to me the benefits of a 3-wheeler compared to a 4-wheeler?
many thanks in advance.....
Wayne Swartz
03-14-2005 12:33:31
 Re: 3-wheeler tractors in reply to heiko, 03-13-2005 10:03:04
Tricycle tractor advantage _ unbelievable maneuverability. beside that, they handle well.
lgc
03-14-2005 06:11:16
The tricycle tractors were popular here in west tenn during the 1950-1960 period. Before weed killers became available. We cultivated crops way to much, but thought it necessary then. In most respects wide front ends were better, but we just didn't seem to know it. BUt if you haven't spun a tricycle tractor around at the end of the row, you owe it to yourself to try it.
heiko
03-14-2005 05:14:24
thank you so much for your kind answers.
as far as I unserstood, this sort of tractor is used for special puposes like cultivating or cottonpicking and it is not spread equally over your continent.
you destinguish between the NFE with just ONE frontwheel and the ones with two narrow frontwheels.
the tip-over-saftey of these machines is serverely discussed....
did I get things things right that far?
tractorpeople seem to be the same kind all over the globe...thank you once again for your help :-))
heiko
from germany, where the spring seems to show up... hopefully
greenbeanman in Kansas
03-14-2005 06:27:33
 Re: 3-wheeler tractors in reply to heiko, 03-14-2005 05:14:24
You are corrrect about the unequal spread of row crop style tractors across the U.S.
I came from the western part of the state of Kansas where the yearly amount of rainfall limits the growing of row crops. Wheat was the primary crop and the row crop front ends were simply not needed nor were 3 point hitches. Three point hitches didn't really start showing up on tractors in my area until the 1960s, except on the small Ford tractors which were few in number.
With chemical tillage came the ability to grow non-traditional crops in the lower rainfall area. Now all of the new tractors come standard with 3 point hitch, now a necessity whereas it used to just be an additional cost with little benefit.
Welcome to the forums.
big jt
03-13-2005 20:52:41
Are you are talking about narrow front tractors (dual and single wheel)?
They got their start here in the US with the Farmall Regular. This was a era when the motor cultivator was in it's infancy. IH just happened to hit on a idea that caught on.
To answer your question simply Row crops have been a major player in the US for years and the narrow front design worked well with the front mount cultivators and corn (maize) pickers here.
hope this answers your question.
jt
Leroy
03-13-2005 18:38:37
They are talking a tricycle type tractor that has dual front wheels set close together and for cultivating about a 30" row was as narrow as would go in the cultivators but a 3 wheel is more or less like the tricycle but with only a single wheel in front and those were mostly used for vegetable cultivation as they could be used on 20" rows as the wheel did not take the spase of dual wheels but some manufactures just thought that it was all the tractor needed like the Avery A and the Silver Kings
buickanddeere
03-13-2005 17:56:32
In the US, east of the Mississippi and in the Southwest vegetable growing areas the rowcrop seems to be common. Even when that chassis is fitted with a wide front. In the plains states and all of Canada the medium and larger tractors were standard chassis. The little odd jobs tractors that cultivated weeds from corn were the only narrow fronts. Around here a narrow front diesel two cylinder Deere 70/720/730 makes people at shows ask."Why the h*ll would somebody buy such a big tractor with such a little front end? Even stranger looks with a 3020 or 4020 rowcrop. We scuffled weeds with small tractors and pulled corn pickers behind the large tractor. Even the wide front, stuck out infront of the tractor is strange compared to the beefy standard axle mounted under the tractor.
Chances R
03-13-2005 14:28:12
third party image
Here is one for you.
Nebraska Cowman
03-13-2005 11:14:42
The main advantage was crop clearence for cultivating
RayP(MI)
03-13-2005 13:29:00
 Re: 3-wheeler tractors in reply to Nebraska Cowman, 03-13-2005 11:14:42
Tircycle tractors with good rear brakes can literally "turn on a dime". Front wheels can be turned far shorter than a WFE tractor, and you can get far closer to obstructions like fence rows. Also far more convenient for attaching front mounted equipment like cultivators, corn pickers, manure loaders. Inexperienced operators often believe the tricycle tractors are prone to sideways overturn. Many experienced operators will tell you otherwise. Used with proper care, they are very stable.
VADAVE
03-13-2005 16:59:04
 Re: 3-wheeler tractors in reply to RayP(MI), 03-13-2005 13:29:00
Your right they turn short and can be use up close to obstructions. However they are dangerous! I know of too many instances where they have rolled over and killed the driver. Experenced or not. Familaity(sp) breds complancy and you can not be complacant with tricycle tractors.
