Tractor Talk Discussion Forum
Normal Engine Wear
Glenn F.
04-28-2005 13:08:20
If a tractor is used properly, what bearings in the engine will likely wear out first? The rod bearings...? Thanks, Glenn F.
txgrn
04-29-2005 06:13:21
 Re: Normal Engine Wear in reply to Glenn F., 04-28-2005 13:08:20
I'm going to agree with rods as they have to absorb the shock of the explosion. The crank (mains) is in a state of rotational motion with built-in kinetic energy to keep it spinning and the explosion is just a little umph to keep it spinning.
Mark
dilbert
04-29-2005 20:41:08
 Re: Normal Engine Wear in reply to txgrn, 04-29-2005 06:13:21
Oh man txgrn, would you ever have the instructor that I had come down on you for saying "explosion" Explosions don't happen in an internal combustion engine and the engine still stay intact.Its a rapid burn,my man.Kind of a whoosh ,not a boom!
msb
04-28-2005 20:09:15
That depends upon the engineering that went into the engine.In most engines there should be little difference in either rod or main bearing wear.Some souped up engines will stretch the rods and then the rod bearings are the first to go if the crank doesn't go first.
Nebraska Cowman
04-28-2005 15:54:54
I don't know if the rod bearing "wear out" any faster but they are a little less forgiving to excess clearence.
