Tractor Talk Discussion Forum
super c - 6 volt to 12 volt
menpap
05-26-2005 09:27:28
my pap and i are in the process of switching over a super c from 6 to 12 volt. i have questions on the wiring. where can i get some info. on the proper wiring. a diagram?? if someone would be kind enough i could try to explain what i am confused on. any info. is greatly appreciated. good day.
KenSWLA
05-26-2005 18:07:10
 Re: super c - 6 volt to 12 volt in reply to menpap, 05-26-2005 09:27:28
Go to the Farmall board. Someone will direct to some wiring diagrams. If not, look in the Farmall archives.
john in la
05-26-2005 15:54:29
While I am a ford man and know very little about a super c so I can not help you with mounting the alternator or such; if you are using a delco 10si alternator I may be able to help you with the wiring if no one that knows the c better answers.
You may try reading my write up on a conversion for a ford and looking at the wiring diagram link near the bottom of the post for some ideas.
