Tractor Talk Discussion Forum
Farmall H hydralics
Linacmechanic
05-26-2005 22:18:13
Can I use the hydraulic pump on my H to power a wood splitter? I tried running a hose to both return ports to make sure things flowed alright and when I pull the rod back it stalls the motor. Am I trying to do some thing the tractor is not capable of?
riverbend
05-27-2005 19:07:41
 Re: Farmall H hydralics in reply to Linacmechanic, 05-26-2005 22:18:13
I think others have said that the hydraulics on an H are too slow (low gpm?) to be really useful with a log splitter.
If dead heading the hyraulic pump will stall the motor, either it is really tired or the pressure relief valve is not working.
Try T-ing the return line into the fill pipe or the drain plug. What are you going to do to return the ram ?
RustyFarmall
05-27-2005 04:28:06
If your H has the standard belly pump there are no return ports. All of them are pressure, for one way hydraulics. If you want to power a log splitter, you need to add a two way valve. It gets a bit complicated, but it can be done.
