Tractor Talk Discussion Forum
rim for wd
mark1952
06-09-2005 10:33:40
were can I buy a non adj rim to fit my wd 8 lug so I could put 14.9 x 26 or 12.4r x24 tires on it? I want to be lighter and beable to pull in 2
KCTractors
06-10-2005 08:56:25
 Re: rim for wd in reply to mark1952, 06-09-2005 10:33:40
I have one with a 13.6x26 tire on it. Located in Central Wi.
big jt
06-09-2005 23:02:25
Hey Mark
How are you coming on that project? What engine did you decide to use?
As to the rims I don't have a specific answer but there were only a few bolt patterns used in that era. I know a lot of Deere and IH utilities used the same bolt pattern. Only thing to watch for is to make sure you have clearance for the Final Drives. I got into this trouble trying to put on spin out rims off a IH 330U. Just didn't have the clearance.
By the way if your old spin out rims are good DON'T haul them away to the iron man. Lots of guys including myself would like to have a chance at them.
HTH
jt
caseyc
06-09-2005 10:49:34
i now some rims off old JD combines will fit, not sure what models though. my buddy has a WD with rims off a 55 model JD combine but i think they are bigger than 26". hope this helps alittle.
casey
