Tractor Talk Discussion Forum
OY...Problem with grandmas car.....
John M
06-25-2005 02:28:09
Ill try to make this short,Grandma has a 1992 Chevy Lumina,6 cyl is all I know and it has about 120000 miles on it.Will start and run fine and all of a sudden cuy off like when she slows down to pull in the driveway or stop sign or the like,then is hard to start for a minute,runs like crap the clears up and the whole thing starts over again.Desperate to get her going agagin,anyone have any clues?
John M
06-25-2005 09:54:47
 Re: OY...Problem with grandmas car..... in reply to John M, 06-25-2005 02:28:09
Well, I dont know much about these "new fangled" cars but I do know the torque converter thing has been unplugged for some time now.It messed up last year about this time,but the guy that did that said not to worry about it so we didnt tell her.The most she drives this car a week is about 20 miles,so didnt think it was going t obe that big of a deal,but maybe it has caught up to it.It idles a little ruff,and we just couldnt find anything wrong on the outside,so we basically begged her to take it to a shop and she finally agreed.This car should have gone to the scrap heap years ago,it has been wrecked several times,and the last time it was hit the insurance comapny wanted to total it but she wouldnt have none of it.It was the last car her and my grampa bought before he died and she just doesnt want to let go.I was wrong on the miles too,its got like 240000 on it.Thanks guys!
Bob
06-25-2005 08:13:14
Sticking torque convertor lockup clutch, EGR valve sticking open or idle air control motor sticking, and failing to control idle would be the prime supsects.
Revredneck
06-25-2005 05:54:30
John,
It sounds to me like the torque converter clutch is sticking. It's a common problem with the 3 speed auto transaxle on that car. To check it out, find the electrical connector located on the front side of the trans near the cooling fan. Unplug the connector and take her out for a drive. That will prevent the converter from locking up. If that's the case, it'll need a TCC solenoid, located inside the side cover behind the LF wheel. If you can't get to it for awhile, or if money is a problem, it won't hurt to drive it with the thing unplugged for a while. But understand that the gas mileage will be much lower. Good Luck and God Bless, Tommy
JDeere BGuy
06-25-2005 19:10:31
 Re: OY...Problem with grandmas car..... in reply to Revredneck, 06-25-2005 05:54:30
Generally the "locked up" Lock Up Torque Converter was a problem with the THM125 transaxles... I had a 93 Lumina with a V6 and it had a THM325 I believe. Is the Check or Service Engine Soon light on? Might try a fuel filter... inexpensive and probably needs one any way at 120,000. Bruce in NE Indiana
buickanddeere
06-25-2005 05:27:53
Throttle position sensor will cause those symptoms as well. It's a moving electrical variable resistor that wears until contact is intermittent. Does the car smoke from the tail pipe or lean out? It could be from water and/or dirt getting stirred up in the fuel tank. Hitting the brakes causes the sloshing. I doubt that she accelerates fast enough to cause the problem to occur then.
Bill in NorthCentral PA
06-25-2005 05:10:29
Try AutoZone or another parts supplier. Often they can hook up to the car"s computer and diagnose electronic equipment. Having said this, I"m not sure that this car has the correct computer to hook to or not.
Good luck,
Bill
jddriver
06-25-2005 03:20:24
Check the o2 sensor and mass air flow sensor
tractordream'n
06-25-2005 05:08:16
 Re: OY...Problem with grandmas car..... in reply to jddriver, 06-25-2005 03:20:24
The timing may need a little adjusting. try advancing or retarding it +/- 2 degrees
caseyc
06-25-2005 05:29:19
 Re: OY...Problem with grandmas car..... in reply to tractordream'n, 06-25-2005 05:08:16
sorry man but there is no distributor on that car. all computer controled with coil packs.
buickanddeere
06-25-2005 05:21:28
You are kidding..... ..... ...right?
gryrt
07-03-2005 22:08:19
 Re: OY...Problem with grandmas car..... in reply to buickanddeere, 06-25-2005 05:21:28
ryy
tky
07-03-2005 22:13:05
 Re: OY...Problem with grandmas car..... in reply to gryrt, 07-03-2005 22:08:19
rykr
euyqwu
07-03-2005 22:14:18
 Re: OY...Problem with grandmas car..... in reply to tky, 07-03-2005 22:13:05
uerwre
