Tractor Talk Discussion Forum
8N continues to sputter and die
Lost
06-25-2005 09:48:20
8N is starting, running about 3-5 minutes and then sputtering and dieing. Acts like it's not getting gas.
Any suggestions?
Bill(Wis)
06-25-2005 11:39:46
 Re: 8N continues to sputter and die in reply to Lost, 06-25-2005 09:48:20
Also, look thru yesterday's 8N board posts for your problem perzactly.
Dan
06-25-2005 11:35:16
I don't know if you have already tried this yet, but remove the big bolt from the bottom of your carb and catch the gas in a clean container. Watch it for several seconds, it should keep streaming a nice solid stream. If it starts to dribble after a few seconds, you have one of your three gas screens clogged. There is one on top of your fuel shut off valve and sets INSIDE your gas tank. There is one inside your fuel shut off valve that you can see when you remove the glass bowl. And there is on INSIDE your carb on the brass fitting the fuel line screws into.
Good luck,
Dan
