Tractor Talk Discussion Forum
O/T force feeding calves
Tim...Ok
07-19-2005 10:54:59
Bought the kids some young bottle calves this past weekend,to give"em something to do..Already lost one,other two ain"t doing good either.. Anybody tried the do-hickeys (feeding tube)down the throat and force feeding colostrum?? They ate good bout the first day,but so weak now they can barely walk.. We didn"t feed colostrum to start with,just replacer,cause we thought they were a little older,startin to doubt that decision now.Any tricks out there ya care to share,they are scourin bad too..We"ve tried electrolytes and eggs in their bottles..
Help,
Tim
Tim...Ok
07-20-2005 07:45:10
 Re: O/T force feeding calves in reply to Tim...Ok, 07-19-2005 10:54:59
Thanks everone,
Enough good calf info here to write a book..I"ll post the results in a few days..
Thanks again,
Tim
kyhayman
07-19-2005 19:12:04
To answer the specific part of your question, yes the tubes work. Just make sure to get them all the way in and dont force them they will go down. A tiny bit of white Crisco helps reduce irritation. I do cow calf so dont have to feed one too ofter but when I do it is exclusively with the tube (I dont own a calf bottle).
In the larger picture, I think you have good advice here. For electrolytes I normally use powdered Gatoraide. I'd forget the LA200 and use a sulfamethiozine bolus, preferably one with kaolin in it. Norden makes a good blue one I get at the vets. If they need a shot something along the lines of Nuflor would probably be called for.
As weak as you describe, I'd be thinking vet, and soon. So far I've had about 70% survival of semi conscious calves that I got to the clinic. It isnt cheap but IV fluids may be called for.
Paul Janke
07-19-2005 18:50:27
Forty years ago (how can it be that long ago so soon?) when we bucket fed calves milk replacer us kids were told to never give them as much as they wanted. They were always hungry, and if not they died. These were holsteins, and they didn't seem to need a reason to give up and die. The way things are done may have changed already since then.
john in la
07-19-2005 18:40:29
This is really hard to do because I have not seen the calves. I may notice a big point you forgot to mention.
You said they are scourin so lets start there.
If these calves did not get colostrums from their mom you can forget about trying that now. It is to late.
If they did get their colostrums they can still come down sick very easy coming from a sale barn.
If they are scouring GET THEM OFF THE MILK NOW!!!!! !!!!! !!
Replace the milk with this
20 teaspoons of dextrose (white corn syrup)
4 teaspoons of table salt
3 teaspoons of baking soda
1 gallon of water
You can substitute glucose for the dextrose but under no circumstances can you use sucrose (table sugar). Calves can not digest sucrose.
You can try the tube if you want to or you can slowly squeeze the bottle and let them drink it down like that.
My wife has success using children’s pedilite when I have all but give up.
Now you need to figure out what went wrong. Are you feeding them to much at one time. 8 to 10% of body weight per day broke into two feedings is enough. While a big calf like a holstein can take two full bottles a day a smaller jersey size calf only needs 3/4 a bottle twice a day.
In fact if you give them more you can give them scours. A baby calf only uses 1 of its 4 stomachs when on milk. If you give it more than this 1 stomach can hold it will spill over into the others and sit there till it goes sour.
Calves that get sick 2 days after coming from a sale barn more than likely got pneumonia or other respiratory diseases. I have found it cost affective and a good practice to get some one time nose spray for the calves. Give it to them as soon as they get home. I can not think of the name right now but a vet will know it well.
For this group I would get them on the electrolytes right away and get a vet to look at them ASAP. LA is good but your vet can treat the real problem and not just hit and miss with a all-round drug.
Dinglebery
07-19-2005 18:30:49
When starting new calves always start with one-half amount of milker replacer but 2 quarts of water. After a while increase replacer up to reccomended levels. Some replacers are so good or rich I was never able to get to reccomended levels. Colostrum after 24 hrs. is a waste of money. Gatorade is good home electrolyte. Remember Pneumonia always follows scours and vise versa. La 200 and sulfa boluses work synergistically. Intestinal protectants are also good-Pepto or Kaopectate. It is not supposed to be used in milk replacer but I always do--easier.
Usually when calves refuse milk they almost always have a fever. It never hurts to get Veterinarian to teach force feeding technique for your first time--you can drown them-I always try to teach my clients to use force feeder. We also can suggest other drugs that may help treat an already sick calf. I feel the summer months are the worse time to raise bottle calves-poor exchange rate for oxygen-too himid. Cooler months are much easier to have good results.I have raised over a hundred calves in my lifetime so I speak from experience. The previous statements about dehydration are true.
Davis In SC
07-19-2005 17:57:12
Years ago, we raised newborn calves, It was a lot of trouble... We lost some at first, but got better as we learned. I remember one, he was in bad shape from the scours, the vet told us to mix a Half -pint of whiskey in a quart of water.calf drank it. He hollered all night, I guess he was drunk... But he was better the next day, & he did OK...
Farmall Teen
07-19-2005 17:05:34
When you buy a new calve, make sure they get plenty of freash water and hay plus grain.
DRL
07-19-2005 14:52:36
Tim,
If they are still alive, would call a vet in ASAP since you haven't had much experience with baby calves. Think baby calves are about the hardest thing to keep alive if separated from mom. When I still lived at home, we usually had 15-20 bucket calves. Was a never ending cycle of shots, scour pills, pink eye meds, etc... You had to be on your toes in order to spot anything that might be going wrong. One day they are fine, the next scours or a cough, dead the next. If you didn't spot a problem eary, you were usually too late. Think I would rather have milked 15-20 head rather than this.
Errin OH
07-19-2005 13:01:27
Would need more info to be very specfic.
What breed, How much you feeding them, How many times a days, Where you keepin them, barn, etc..., How does it progress and such.
Generally speaking a calf/cow is about the dumbest thing to walk the planet. Will stand there and stare at ya with that I am hungry look and not eat the food laid before them. Without seeing and going on my own experances, I'd say dehydration is you worst emeny. They get the slighest ill filling and they stop eating/drinking. That starts one big snow ball. They get up one day and are slow/finicking to food, the next morning they won't eat, by the third the won't even get up. Day four and they are dead. Between scours and no drinking they die of dehydration. Tubing isn't that hard. When you get their neck between your legs, lift up on the chin, the tube will just about guide itself in. Mine came from TSC. Just hang on to them until the bottle is empty. They won't like it and may try to pull away and/or drop their a$$ on the ground. General rule around here is 6 quarts liquid a day, split up between 3-6 feedings, equal (close to) times apart. I try and make two of them electrolites. Beyond that you need to find out what is making them feel ill. Do they have a cough and/or snot nosed? If so, maybe a couple liquamycin (general antibodic) shots are in order. Are they getting over heated? Shade and fan will help. Are bottles and such clean? I have had trouble with contamination before and didn't even known it. Watch milk replacer storage (d@mn mice). If they are scouring (runs) you may have to go an extra step to cure/stop it. In my case it was more manage (nasty winter bug) until soild food more than anything.
As for colustrum, its to late and don't waste you money. If they didn't get it in the first 24 hours it won't do any good now. Put them on a good Replacer (not soy milk) and provide electrolites. Manage the dehydration, tube if necessary, I tubed one three times a day for a week before he got back up on his feet. Try to fix/adress the underlying cause. I would avoid the raw egg thing, salamnila(sp) is a bad thing.
Tim...Ok
07-19-2005 13:49:20
 Re: O/T force feeding calves in reply to Errin OH, 07-19-2005 13:01:27
They are to the point,they want nothing to do with the bottles now.. They are sale barn mix,look a little brahma,but who knows..They are covered with a fan on them,clean bottles and replacer..I think the replacer got them scourin in the first place,it"s the medicated version from a reputable feed co.but it seems a little rich when mixed per instructions,we"ve had great luck with it for years though.. They have had 2 shots each so far,3 cc"s of LA per dose. We"ve been putting the elctrolytes in their replacer,just how we"ve always done it,but will try without the replacer..with the tube.
Thanks everybody for all the help,
Tim
mike brown
07-19-2005 12:55:57
they need electrolyte solution. You can make your own but I've forgotten the ratios but it's water sugar,salt, baking soda. you need to stop the milk, colostrum and replacer because it is feeding the bad bugs in their guts. They also need antibiotics in the water. I used to pick up calves that were half beef at the auction house and lost at least half and gave it up.
onefarmer
07-19-2005 12:27:15
Do a google search on calf scours!!
milk fed calves have a hard time after being moved. They scour very easy.Worse if bought out of a stock yard, many bad bugs in one place. Basicly no food for the first 24hrs. maybe some water.
Watch carefully for dehyration. If they are scoured they will dehydrate fast. Do a pinch test. Pinch some skin if it stays tented they are getting dehydrated. If the calf won't eat/drink and is getting dehydrated then it is time for the feeding tube, electrolites and water. maybe add an egg for the protein
onefarmer
07-19-2005 12:42:38
 Re: O/T force feeding calves in reply to onefarmer, 07-19-2005 12:27:15
Keep the calves separated so they don't infect/reinfect each other.
Coloken
07-19-2005 12:24:04
Too late for colostrum--need it as early as posibly, even hours are important. Feeding tube is the proper way. Fluid into the lungs is instant death-been there, did that. Don't feel bad, even experts have great problems with baby calves. All most imposible to keep them alive once they and the grounds get infected. IV with electrolytes. Very hard to find the vein in a dehydrated calf. BTW, Cambell's beef consumey (sp?) is considered a very good fluid, like the electrolyes. Old ranchers use lots of eggs. Milk is probable the worst thing to aggrivate the condition. Kennyp
Tim...Ok
07-19-2005 12:03:47
I"m guessing here,but I"d say they aren"t more than a week old..
GregCo.
07-19-2005 12:56:10
 Re: O/T force feeding calves in reply to Tim...Ok, 07-19-2005 12:03:47
Everybody has pretty much hit it on the head here.
Okay, if they were mine here is what I would do.
Will they still take a bottle? If not you are going to have to tube all the good stuff back into them.
I would get a vet involved today.
I would cut out the milk or replacer for now. They will dehydrate long before they starve.
I would get some NutriDrench in them ASAP. This stuff is great for sparking an energy spirt. It has propylene glycol in it witch is a form of sugar. It also has other supportive vitamins and minerals. I have seen this stuff do wonders in holding animals over until the vet can get there. Any good feed store or COOP should have it.
I would keep up the electrolytes.
I would give probios to jump start the gut. If the good bacteria in the gut dies so will the animal.
It will be important to find out what is causing the scours. They are loosing much needed water and nutrients. Here again the vet will be able to point you in the right direction.
Personally I think they are a bit young to have a Cocci problem just yet, but?
If they did not get some colostrum from mom you are going to have a long battle on your hands to keep them alive and get them to recover, but it can be done.
Let us know how you come out.
GregCo.
07-19-2005 11:28:00
How old were they when you got them and how old are they now? If they never got colostrum from their mom it may not help now. Some BioSol may help with the scours but it would be helpful if you knew what was causing the scours to start with.
If you are using replacer that may be part of the problem. Some of them are a little too rich and can cause scours. I have seen people cut back on the mix and have better results. If you can get it goat milk works good too. I would also wonder if there isn’t a parasite problem? Coccida can cause scours real bad and even kill the animal.
Here is some info on Coccida.Link
Hope>Link you get this figured out.
If they were mine I would have a vet do a fecal to eliminate parasites and keep the electrolytes going so they don’t dehydrate.
Good luck with this.
Bobl1958
07-19-2005 11:14:08
I would say if you didn't get calves that were started on the cows you are probably in trouble. The first couple of days of mom's colostrum pretty much sets their immune systems up. We used to have lot's of cows and calved in the winter. Used to have to bring several in during bad winter weather, but it was very hard to keep them alive. I would assume there might be some sort of new fangled starter, but don't know for sure. You should probably talk to a vet to see what they have now a days. I don't know if scour pills will help or not, again I would call a local vet.
hanbertem
07-19-2005 12:16:20
 Re: O/T force feeding calves in reply to Bobl1958, 07-19-2005 11:14:08
There are some commercial tubes of beneficial microbes, vitamins, etc. you can get over the counter at virtually any good feed store. when they are little they go fast if you don't get on it in a hurry. Get the Probios tube in them quick as you can. Be careful with tubing them because it's easy to get the tube in the lungs and not down the throat. Put it in and listen for breath sounds in the tube before you tube them. keep them warm and hydrated, hope they got some colostrum absorbed. Get the best milk based replacer you can, avoid the soy/ wheat stuff at least for now. First 15 days are always critical, they go through a period of time where they have no natural immunity or ability to absorb any additional from an outside source. Little bits of death looking for a place to happen. Good luck
joe e-tx
07-19-2005 19:03:48
 Re: O/T force feeding calves in reply to hanbertem, 07-19-2005 12:16:20
learned a lot from this thread shipping fever???
joe
