Tractor Talk Discussion Forum
Farmall H Temp Gauge?
Adam Zich
08-15-2005 06:33:17
I noticed the other day that the temp Gauge on my H wasn't working. Is there a common problem with these? or somthing obvious I can check for? Thanks,
-Adam Zich
RustyFarmall
08-15-2005 08:18:04
 Re: Farmall H Temp Gauge? in reply to Adam Zich, 08-15-2005 06:33:17
Just to add to what the others have said, if your coolant is low, the temp. guage sensor will not be in contact with the coolant, and will appear to be not working. I doubt if this is your problem, but it's worth checking on.
Tim [nga]
08-15-2005 07:14:50
To check the gauge. Turn on the ignition swich, do not start the tractor. Locate the temp gage wire on the engine block. Remove the wire from the sender and ground the wire. Does the gauge show hot. If not check the gage.
Buzzman72
08-15-2005 07:48:59
 Re: Farmall H Temp Gauge? in reply to Tim [nga], 08-15-2005 07:14:50
IIRC, unless it's a replacement gauge and sender, the Farmall H used a gauge that was attached to the sending unit with a tube...not a plastic tube like some of the cheap aftermarket oil pressure gauges, but a metal tube, because the sender and tube are liquid-filled. You replace the temperature gauge ASSEMBLY, which includes the gauge and the tube and the sender as a single unit, on the Farmall H...as well as a lot of other Farmalls of the era.
So no wires are involved.
Joe in Minnie
08-15-2005 06:43:50
Depenting how old the gauge is, if it's old, it could be rusted inside, and that makes them stop working, just change it out, If it's relatively new, then take it out and take it back where you bought it, some times you get a bad one...
