Tractor Talk Discussion Forum
MM R Rear Platform
Jon Feldman
08-15-2005 20:16:26
I recently bought a 44' Minneapolis Moline R the fenders are connected to a rear platform with the draw bar mouted to the bottom of the platform and to the rear end was this an option or something aftermarket? It id obviously made for the tractor but have never seen one like it,any help would be appreciated!Thanks! Jon
old
08-15-2005 20:40:20
 Re: MM R Rear Platform in reply to Jon Feldman, 08-15-2005 20:16:26
That means its probably an RTU which makes it untility
Jon Feldman
08-15-2005 20:46:33
 Re: MM R Rear Platform in reply to old, 08-15-2005 20:40:20
Are they common or worth anymore?
old
08-15-2005 20:51:48
 Re: MM R Rear Platform in reply to Jon Feldman, 08-15-2005 20:46:33
I have had both so they are about the same as the others.
Jim Broughton
08-15-2005 21:27:20
 Re: MM R Rear Platform in reply to old, 08-15-2005 20:51:48
Jon; "Old" is correct, your MM is an "R" utility, and they are about the same, though I believe the "utility" was available in a higher gear ratio, great for discing, but kinda puny with a plow ! Hope this helps ! Jim
