Tractor Talk Discussion Forum
Stihl 034 chainsaw
John Laskowski
08-20-2005 14:08:00
today when i started the saw it idles fine but when i give it throttle it bogs down. when it does throttle up, under any load (cutting) it bogs down. any suggestions.
thanks
john
RustyFarmall
08-21-2005 16:11:51
 Re: Stihl 034 chainsaw in reply to John Laskowski, 08-20-2005 14:08:00
Clean your air filter.
farmermatt
08-21-2005 00:09:20
Pretty new saw but just incase check the feul line in the tank and up to the carb to make sure it doesnt have a crack letting it suck air under more fuel demand.
2x4
08-20-2005 22:34:32
if those 2 suggestions dont work, rebuild your carb
Nor. Al.
08-20-2005 14:41:27
John your problem is a common one for a 2 cyle engine ,go into the little muffler and take out the little mesh screen spark arrestor and clean it or as I do just leave them out and put cover back on the muffler!
Bill(Wis)
08-20-2005 14:18:50
Did you make sure the chain safety brake was released?
chris sweetland
08-21-2005 19:35:42
 Re: Stihl 034 chainsaw in reply to Bill(Wis), 08-20-2005 14:18:50
i have the same saw the little plastic chain guides and chip shoot were rubbing after i put a new chain and bar on so i took them out work fine i have put about 80 hours on it since and everything is still good
