Tractor Talk Discussion Forum
tubeless tire
Russ Smart
09-11-2005 07:04:10
We have a 2001 JD 4600 with 17.5x24 wide bar industrial rear tires, and one of them has developed a slow leak, noticeably low in 2 days or so. There is no fluid in the tire, which might make it easier to find, but the corrosion! We have been over it with soapy water 3 times and can't find any leak. I was planning on using fix-a-flat but was told that some brands are corrosive, now SLIME was recommended to me. any ideas? Thanks in advance. Russ
old
09-11-2005 08:11:37
 Re: tubeless tire in reply to Russ Smart, 09-11-2005 07:04:10
I'd go with the slime or put a tube in the tire.
Leland
09-11-2005 13:11:22
 Re: tubeless tire in reply to old, 09-11-2005 08:11:37
I have put about 10 gallons of real soapy water in tires then pumped them up to 40-50 lbs and slowly spun then you can usually find any leak this way is there something stuck in bead check it also .
