Tractor Talk Discussion Forum
farmall C water pump?
Bill Pingel
09-22-2005 19:35:00
I have a farmall C and want to add a water pump. I bought a super C water pump and it does'nt fit.Any kits somebody knows of or any help would be appreciated. thank you Bill
THEkyroastnear
09-23-2005 20:40:00
 Re: farmall C water pump? in reply to Bill Pingel, 09-22-2005 19:35:00
its too late tonite but i will be down at my toolshed looking i am sure my C has a waterpump i thought they all did
Irv Plitzuweit
09-22-2005 19:45:29
Went to Case IH dealer in Plainview MN and bought "kit" water pump for my C farmall. Came with new longer fan belt and gasket. Put it on and it worked so good, that I bought one for my Farmall A and put one on it. No more boiling or "burping" after shutting off tractor after working hard.
Dale in Ar.
09-22-2005 19:41:15
Bill,you can't put a water pump on a "C" Farmall.They weren't made to have one.If you want to put a water pump on a "C" Farmall you will have to change the front end to a Super "C" and have a 123 engine.Also you will have to raise the gas tank about 2 inches to conform to the lines of the hood and radiator.
Bill Pingel
09-24-2005 19:36:16
 Re: farmall C water pump? in reply to Dale in Ar., 09-22-2005 19:41:15
Been to case dealer and got all the parts and everything works fine. The problem I was having was I was trying to put it on the top radator hose.It goes on the bottom one. Thanks everybody Bill
Red Dave
09-23-2005 09:32:47
Lots of C's have had water pumps added. And a whole lot of A's B's & Bn's got them too.
A Case/IH dealer should have the parts you need. I've seen them from aftermarket suppliers too.
