Tractor Talk Discussion Forum
Plug fouling out on one cylinder
AL BANE
10-07-2005 13:36:14
I have a Farmall 300 and it has one cylinder that will foul out with oil after about 4-5 hours of use. The tractor has a slight miss with a fresh plug but does not miss under a pull.Tractor does not smoke. What do you think?
sammy the RED
10-07-2005 18:13:20
 Re: Plug fouling out on one cylinder in reply to AL BANE, 10-07-2005 13:36:14
Is it #3 or #2 cylinder ?
al bane
10-07-2005 18:48:15
 Re: Plug fouling out on one cylinder in reply to sammy the RED, 10-07-2005 18:13:20
number 2
the tractor vet
10-07-2005 18:05:52
First off make sure that you have solid core wires, install a new cap and rotor , Do a fine tune adjustment on the carb , adjust the valves , and check the timming and set as per spec. change your grade of gas , And do not use champion plugs. Use either Motor Craft Autolite or A/C's .
hay
10-07-2005 14:57:23
perhaps a bad, worn, or missing valve stem seal. that lets oil leak past the valve stem and get into the firing chamber and thus fouls the spark plug. do a compression test first on the entire engine.
Weirsdale George
10-07-2005 13:53:48
Need to do a compression test. My first guess would be either stuck or broken rings on that cylinder.
Jerry/MT
10-07-2005 13:50:20
Sounds like you have a bad cylinder(worn sleeve, worn/stuck oil control rings). Have you checked the compression? What about checking the spark?
Weirsdale George
10-07-2005 13:56:08
 Re: Plug fouling out on one cylinder in reply to Jerry/MT, 10-07-2005 13:50:20
Jerry/MT -- you beat me by three minutes!
Jerry/MT
10-08-2005 11:53:14
 Re: Plug fouling out on one cylinder in reply to Weirsdale George, 10-07-2005 13:56:08
Well shoot, George, every dog has it's day! Usually I'm a minute late and a penny short.
