Tractor Talk Discussion Forum
OFF TOPIC. OLD OUTBOARD MOTOR
Mike in Ind.
10-10-2005 17:42:58
Anybody out there know much about old evinrude boat motors? I need help Identifying(Year,HP) one me and my friend pulled out of the bottem of the local river(took both of us! He weighs about 285 or so and I'm about 210 or so). I reckon by the looks of things It was down there for the better part of 40 or fifty years. It is a Evinrude two cylinder motor. Air cooled I assume due to the small fins on the sides of the cylinders. Has hook ups for A tank and hose. It has a glass sediment bowl under the carb, The pull cord is on top and off set to the right side. Has a Big black knob in the center of the back side for adjusting the fuel mix? Two more small knobs for ? Lever that goes side to side for the throttle. Forward and reverse lever on the side. Thats all I know to tell you other than that It is blue. Maybe a Hammered finish? Not sure due to all the crud on it. It's not very often you catch a boat motor when your out fishing! LOL! Thanks for any help. Mike.
Dan67
10-10-2005 20:51:17
 Re: OFF TOPIC. OLD OUTBOARD MOTOR in reply to Mike in Ind., 10-10-2005 17:42:58
I.am a outboard mechanic by trade and a tractor person by hobbie, If you can find the model tag on the transom clamp area I can tell you the exact year. The knobs on the front are carb adjustment the upper (big) knob is the low speed mix needle the bottom is the High speed mix knob. if you need any more info I beglad to help
jfp
10-11-2005 02:26:49
 Re: OFF TOPIC. OLD OUTBOARD MOTOR in reply to Dan67, 10-10-2005 20:51:17
While we are at it, what is a Ted Williams 25 horse worth all orginal? I know Sears just stuck their name on them. And can you still get parts?
Martini
10-11-2005 05:11:57
 Re: OFF TOPIC. OLD OUTBOARD MOTOR in reply to jfp, 10-11-2005 02:26:49
Also check here!
www dot aomci dot org/askamember/index.html
