Tractor Talk Discussion Forum
Getting a correct cylinder size
al bane
10-11-2005 11:56:39
I have a Farmall 300 tractor and I an redoing the rings and sleeves. The number on the piston is Z16 ON TOP AND BELOW THAT MUMBER IS 374299-RIB AND THOSE LAST 3 COULD BE R18.If anyone has any information of the cylinder size for this piston, please let me know.I've been to an I.H. dealer and to NAPPA and they couldn't help me. thanks-al bane
DWV
10-12-2005 18:43:57
 Re: Getting a correct cylinder size in reply to al bane, 10-11-2005 11:56:39
Thats a 3-5/8 fire crator piston with a .875 wrist pin.
ejr-IA.
10-12-2005 08:06:23
If you are replaceing with new go with the 35/8 makes it a c175 cid like a 350 motor.
RodinNS
10-12-2005 07:06:04
Do yourself a big favor. Either get a set of mic's or a vernier caliper and snap gauges. The caliper is available for about 30 bucks for a decent offshore digital. I'm guessing that if you round out the hundred, you will also have the snap gauges.... Then you can measure the pistons, sleeves and all the bores. A hundred bucks is far cheaper than buggering an engine job because of mismatched pistons. You should still check the bore as a matter of course. Not doing so is not worth the risk..... ....
Rod
Duner Wi
10-11-2005 18:49:52
Pay attention to the wrist pin dia. also. Pistons may come with .875 pins versus the other size which is 1.1088 in. dia. Adaptor bushings are available from IH #366883R92. I am assuming you are doing the pistons as well as the sleeves.
Nebraska Cowman
10-11-2005 15:59:32
do you have a steel rule? they are likely either 3 5/8 or 3 9/16 and even I, if I take my glasses off and use my imagination can tell within a sixteenth.
third party image
alan bane
10-11-2005 20:59:20
 Re: Getting a correct cylinder size in reply to Nebraska Cowman, 10-11-2005 15:59:32
Today at NAPA the Farmall 300 showed 3 different sizes of cylinders--what are the 3 sizes, and by the way do you measure from side to side of the cylinder or from side to side of the sleeve?
Bob
10-11-2005 12:06:41
Can't you measure the piston with a micrometer?
al bane
10-11-2005 12:14:47
 Re: Getting a correct cylinder size in reply to Bob, 10-11-2005 12:06:41
Sorry Bob, don't have one of those--thanks anyway--al
Tim...Ok
10-11-2005 12:29:38
 Re: Getting a correct cylinder size in reply to al bane, 10-11-2005 12:14:47
Your gonna have to get those pistons outta there if ya plan on replacin"em.. getcha a cheap set of snap gauges and a pair of dial calipers,use the snap guages to measure the hole,then measure the guage with the calipers..micrometers would be way better,but calipers will getcha in the ballpark..
Tim
