Tractor Talk Discussion Forum
kinda off topic,tractor dump trailer
indianheadranch
10-18-2005 06:34:29
I seen on here a couple month’s back about a guy building a dump trailer from an old truck I have a 80 horse tractor and was wondering if anyone new how to do this, I have a hydraulic pump off of a td9 bulldozer and a friend of mine has an old ford dump truck a 3 or 4 yarder I want to take the truck cut it into and make a dump trailer run the pump from the pto with it’s on tank and spoil valve to be mounted in the cab of the tractor will it work any thought’s or suggestions,all replies welcome
Farmered
10-19-2005 02:48:51
 Re: kinda off topic,tractor dump trailer in reply to indianheadranch, 10-18-2005 06:34:29
I made mine from a 1 1/2 ton 35 Ford. Used a single hose. Plugged right into the Power-Trol on the AR Deere. I put high sides on it and used it for a combine tender before there was such a thing a gravity boxes or grain carts. That was back when I used a JD 45 for custom harvesting.
Tractor Dan
10-18-2005 17:06:03
my dump wagon is same as mlm said his is but used rear axle welded to from removed springs to lower it i just hooked hoses to cylinder to run to tractor remotes works great i mostly use for fire wood but the ocational load of gravel
JMS/MN
10-18-2005 10:46:58
I was one of those who responded to that post with some details regarding the hydraulic setup. I would caution you about having a valve inside the cab, unless you can shield it somehow- in case of a hydraulic leak, you do not want to be in the spray pattern. It can penetrate the skin and cause major harm to your system. Most tractors have a linkage going to a valve outside of the operator area.
mlm
10-18-2005 10:13:17
I have a homemade dump. They cut the frame under the cab. The frame was notched just ahead of the box and the two frame sides v'ed together to form the hitch.
Don't have a seprate pump, I just hook into the tractor couplings.
Bernie in MA
10-18-2005 09:59:17
I did this with a 2-yard body off a 1-ton. It's just right for my 2N. I beefed up the dump subframe and welded a front axle to it so the bottom of the bed is just above my knees. I had to mount a gearbox on it to reverse the rotation to run it off the PTO. I hooked a spring to the control valve and use a rope to control it from the tractor seat. About the handiest thing I ever made, great for picking up rocks.
Gary Mckenzie
10-18-2005 09:59:11
Sure it will work. I built one several years ago and it works quite well. I didn't use a separate pump, the cylinder is operated by the tractor remote. Do be careful when using the trailer, 5 yds of dirt will weigh 10- 15,000 lbs and can cause some control problems going downhill or on slick ground. The loaded trailer can easily weigh more than your tractor and most tractors will have trouble stopping such a load. I use a JD 4240 (110 hp).
