Tractor Talk Discussion Forum
3 point linkage hook up
william pilson
10-22-2005 12:27:14
I'm having quite a time, I added a over running clucth adapter, this required me to cut the drive shaft down a bit as it was too long, now when I raise teh mower the shaft drags the top of the deck, if I adjust teh top link enough to prevent this it won't let the back of the mower down enough to cut right when lowered??!! Help
Roy in UK
10-23-2005 04:32:26
 Re: 3 point linkage hook up in reply to william pilson, 10-22-2005 12:27:14
You say that you have fitted an over-run clutch adapter to your tractor? Oh dear,is it something like a TO or TE Ferguson or a Ford 9N with no position control?
Dwight - VA
10-22-2005 12:51:40
How high do you need to raise the deck? There should be a stop adjustment on the hydraulic touch control that you can set so that the shaft doesn't hit the deck when raised.
wayne2
10-22-2005 13:40:40
 Re: 3 point linkage hook up in reply to Dwight - VA, 10-22-2005 12:51:40
True enough, what tractor are you driving??
