Tractor Talk Discussion Forum
1987 F250 Tranny Oil Cooler Lines
Tweeter
10-24-2005 20:39:05
I have a 87 F250 4x4 and the automatic tranny oil cooler steel lines have a couple pin holes in them and are leaking. Can buy premade lines to replace them and where can I buy them or can I replace the steel lines with rubber tubing with appropriate fittings?
Leland
10-25-2005 17:19:52
 Re: 1987 F250 Tranny Oil Cooler Lines in reply to Tweeter, 10-24-2005 20:39:05
I have taken a small piece of rubber fuel line slit it and put hose clamps over leak and some have held for years .but you should be able to find lines in a junk yard also .
doogdoog
10-25-2005 13:39:42
Aloha, A cheap fix for a pinhole leak would be a compression fitting (one pinhole is just the beginning). A good fix, would be to get some steel brake (not copper)line from the auto parts of the appropriate size and bend it (tubing bender) to the original. I made some for my 400 TH trans (output and input) and it is just like new.
Mahalo,
doogdoog
Brokenwrench
10-25-2005 10:11:55
Not sure on that model, but Ford probably sells them. Some models, the dealer has a part # for them and when they arrive, you get two 4-6 ft pieces of 5/16 line. You have to bend em.
I`d ask cause you can probably get line from a parts store cheaper if that`s the case.
Hope this helps Brokenwrench
Bob/Ont
10-25-2005 10:19:54
 Re: 1987 F250 Tranny Oil Cooler Lines in reply to Brokenwrench, 10-25-2005 10:11:55
Just buy a 25' roll and buy or borrow a Tube Bender and Double Flaring tool. The one with the buttons for each tube size.
Later Bob
jfp
10-25-2005 03:57:37
You can get the lines at a Ford dealer and I would use metal replacements. Some auto parts may carry them. There is more pressure in them on some models than you might think, but don't know about yours.
