Tractor Talk Discussion Forum
AC-B and C set up
BLW
11-23-2005 07:08:06
does any one know any new stuff// to break loose a stuck engine i"ve tried all the old standards but to no avail-
Dick L
11-23-2005 16:32:39
 Re: AC-B and C set up in reply to BLW, 11-23-2005 07:08:06
Fast way to unstuck an engine.
third party image
Keith-OR
11-23-2005 09:20:51
Have you checked to make sure that the crankcase isn't filled with water also. I have used Kroil with great success. You can also make an adapter to screw into the sparkplug hole with a grease zerk on it. Remove valve cover, remove rocker arms as to let the valves close, fill one cylinder with oil up to spark plug hole(make sure valves are closed). Screw in the adapter, use hand held grease gun, pump grease into the oil filled cylinder, grease gun will produce around 2000 psi, which in turn will push the piston downward. Have used this to hydrostat tanks...HTH
Keith
