Tractor Talk Discussion Forum
Farmall 504 rototiller
Liam Newman
12-09-2005 19:14:02
What size width tiller might work behind a Farmall 504 gas tractor, and what kind of gearing should I look for?
TJT
12-09-2005 19:55:23
 Re: Farmall 504 rototiller in reply to Liam Newman, 12-09-2005 19:14:02
I have a 504 Gas Utility that really needs a overhaul and is down on power and I use a 70 inch Rhino Tiller in first gear low side of T/A and it works good. I use it mostly in established crop ground and not much in un-tilled sod. With sod you just don't set the depth too deep on the first pass and go over ground again and again re-setting the depth each time until you get the desired depth. It is slow going!
