Tractor Talk Discussion Forum
your farm shop
rick YYC
12-15-2005 12:57:08
is there something in it you really like? wish was different? or is just so messy it takes your breath away?
I am writing a book about how to equip a farm workshop, and if you'd like to have a picture of your shop featured in it, you could e-mail me and I'd inlcude it with your name and location. Digital pics at 300 dpi are OK. Make a good keepsake.
R
Gene Davis (Ga.)
12-16-2005 18:37:19
 Re: your farm shop in reply to rick YYC, 12-15-2005 12:57:08
I dug a 2' deep hole with my hand post hole diggers and planted a length of 4" steel pipe that had 2" angle iron welded to it at 90 degree angles in the floor where my welding area was to be. When I poured the floor, I then had a secure mounting leg for the vise end of my 1/2" steel plate welding table. The other end of the table is supported by 1/4" X 2" angle iron legs. The pipe anchors the vise end so that when you get to really hammering away on something or pulling on it you don't have to keep chasing the welding table.
Mike (WA)
12-16-2005 08:19:39
My shop isn't especially special (24 X 36, much too small- always more projects than room)- but seeing the workbenches in the other photos with tools nicely arranged on the pegboard reminds me of when I tried to do that, and soon became tired of trips to the wall to get another wrench or return one that I had just gotten- so I got an old grocery cart (one with the high, shallow basket)- removed the basket, and replaced it with an inverted butt shield from a herringbone milking parlor- a piece of stainless about 2' by 3' which, when turned upside down, becomes a tray with about a one inch lip all the way around. My frequently-used tools live on it full time- wrenches, socket sets and ratchets, several screwdrivers, vicegrips, etc.- roughly arranged in different areas. It would be even cooler if I got some of those "tool organizers" and just laid them on it. Just roll it to the next victim, and quit constantly running back and forth to the workbench.
Dan
12-16-2005 07:01:58
third party image
I do all of my tractor work on one side of my two car garage at my house in the city. This pic proves you can have a small shop that is effective, but you MUST be organized and stay that way. I now have a large shop light overhead and a large vise on the corner of my small work surface.
My shop at my property I will build when I move out there, and it will be 40 X 80 and 16' high with a large roll up door on both ends offset closer to one side so you will have work "bays" and a walk through security door. It will have 4" thick concrete floors with two large floor drains (one by the mechanics area, and one in the paint area). I will have a workbench that is 20' long and well lit with florescent(sp) lights. I also will need plumbing for a toilet and a large wash basin. Of course - I am still dreaming :-)
Dan
TomHath
12-16-2005 06:19:23
third party image
Three sided shed, so no matter how big the project is you just drag it up to the front of the shop, and there's plenty of fresh air so you can weld or spray paint without needing a fan. A dirt floor, so spills just go away (and any snow that blows in eventually melts and runs off). All tools out in plain sight...
barnrat
12-16-2005 04:35:57
I love my shop!!! It came with the farm I'm renting it's 30x80 I believe but seems bigger with 16x16ft overhead doors on each end. The guy who had it before me could pull his whole rig and possum belly inside to work on. It's heated with a small "hot" room where I have a sink, my steam cleaner and all the oil. The hot room makes it so I don't have to heat the whole shop all the time. I can work on up to 3 tractors at a time, and still have room to let a friend who has a small excavating businees use the other half to work on his equipment. The only thing I don't like about my shop is dirt and soot have taken their toll causing it to be too dark for my taste. If the sun comes out today I'll try to get pictures to post.
jpuleo
12-15-2005 16:04:13
always go bigger than you think you need. Im trying to avoid that by building a 3 story 31x55 shop (5100sf) this winter. A neet trick that is quite helpfull is to put some pieces of 2" square stock steel in a concrete floor to create a square hole. This is for when you need to hold something secure to the floor that need leverage like manual tire changers or bending metal. Im planing my shop to have machine/blacksmith shop on ground floor, general use on 2nd and the top floor will hold a carpentry shop. I may put a working firehouse pole in just for fun.
wayne2
12-15-2005 17:19:08
 Re: your farm shop in reply to jpuleo, 12-15-2005 16:04:13
I've never built large enough!!20-30,next was 20-40 with room for lean to's around,probably do same with new place! W
37 chief
12-15-2005 15:45:35
A good strudy work bench is good to have, and a good vise is also necessary. both of the pictures show this. The vise in the Nebraska cowman is like the one I have, wich goes back to the 50's. Stan
Nebraska Cowman
12-15-2005 14:26:41
a well-lit bench is a must. I don't do any tractor work in my shop. That's all done outside. third party image
Allan in NE
12-15-2005 15:07:53
 Re: your farm shop in reply to Nebraska Cowman, 12-15-2005 14:26:41
Yes, I agree.
A clean, tidy and well groomed bench and shop is totally essential.
However, most of my tractor work simply doesn't get done, inside or out 'cause I spend entirely too much time on this site. :>)
Allan
third party image
Kent in NB
12-16-2005 05:30:36
 Re: your farm shop in reply to Allan in NE, 12-15-2005 15:07:53
Allan, is that a blender in the middle of your bench?
Allan in NE
12-16-2005 07:54:15
 Re: your farm shop in reply to Kent in NB, 12-16-2005 05:30:36
Heck, I dunno.
Let me get a stick and stir the pile. Never know what the stiring action might bring to the top. :>)
The other day, I asked the wife if she had taken my inside caliper. She just looked at me kinda sideways. :>)
Allan
Kent in NB
12-16-2005 10:36:32
 Re: your farm shop in reply to Allan in NE, 12-16-2005 07:54:15
Calipers?... Right, ice tongs. Stirring...hmmm, Right, blender.hmmmm... . Ok. I have figured out your bench. You are making martinis, and taking to drink, because this HYDRO has taken over your life.
RodInNS
12-15-2005 18:16:21
ROFLMAO.... Love the pic Allan.
That looks like my work table. Only mine is still sitting in the middle of the floor, where it got pressed into service cause I didn't have time to clear the junk from the wall to make space.... Although, I think I've got a bit more stuff on mine right now. Likewise, here, the main 1/2 acre fabrication/repair bay is now covered in about 1' of white crap. I'd like to consolidate that down to about a 40'x80' building someday, when the money rolls in....I'm dreaming of a white Christmas.....not
Take care,
Rod
TomNTexas
12-15-2005 23:56:50
 Re: your farm shop in reply to RodInNS, 12-15-2005 18:16:21
My Father told me to fiqure what size I needed and then multiply by two. Should have listened cause my 40'x 40'gets tight with a couple of vehicles or tractors inside.
First. Give some serious thought to the size requirement. Second. Allocate a specific area for your tools. It's easy to see when something is missing. Most times you will remember where you used it last and left it. Other times I go to asking questions and find it in the wife's utility room.
Tom
TomNTexas
12-16-2005 00:04:36
 Re: your farm shop in reply to TomNTexas, 12-15-2005 23:56:50
third party image
Tim...Ok
12-16-2005 12:08:11
 Re: your farm shop in reply to TomNTexas, 12-16-2005 00:04:36
Tom,your a twisted,sick individual..LOL Just kiddin,that looks real nice..mine looked half that clean,once 8^)
Tim
Tim...Ok
12-16-2005 12:06:51
Tom,your a twisted,sick individual..LOL just kiddin,that looks really nice..mine was about half that good,once..haha
