Tractor Talk Discussion Forum
Before I Do This
Allan in NE
12-20-2005 04:08:44
Mornin' Guys,
I know I'm picky and all that, but some things just strike me as being wrong. I'm running into a lot of "Farmer Engeenering" on this old tractor.
Anyway, I'm replacin' all the heater hoses that the prior owner had on this oil cooler. Needless to say, they sprung a leak. :>)
The oulets on the cooler are pointing up and the hoses were "looped" over and then down to their inlet pipes at the lower left of the radiator.
Shouldn't the hinges and latch assembly of the cooler be reversed and the cooler assembly "flipped", so that the cooler pipes are on the other side and pointing down with the cooler opening from right to left?
Anybody out there own one of these old dogs?
Allan
third party image
Qeebec Red
12-20-2005 10:06:38
 Re: Before I Do This in reply to Allan in NE, 12-20-2005 04:08:44
On the Hyrdo 70D that was bought new on the farm in 1975 the hoses were like yours.They never leaked in the 27 years that we owned the unit. Re one of your previous posts mentioning that your tractor backed up well but did not advance with the same b-lls: my fading memory is trying to tell me that there are "capsules" located externally that are identical-one for forward,one for reverse. They may be interchanged to see if this is the problem. Perhaps someone else more schooled than I can provide better consel. I remember being billed on several occasions for that repair. Dealer stocked the parts. Just a thought, and they were not expensive. The Hydro was never touched internally in 6000 hours, and was puttting out full pressure.Always used HY-TRAN. QR
Allan in NE
12-20-2005 11:17:45
 Re: Before I Do This in reply to Qeebec Red, 12-20-2005 10:06:38
Yes Sir,
I think you are talking about the forward and reverse pressure relief valves. They, along with the two steel pressure lines are located just inside that left cover plate.
I'm gonna pull that plate and take a look; local red shop says that they are hard on the seals on the valves you're talking about.
If it is anything more complicated than that, tho, she is up on the trailer and headed fer town.
I just can't see how it is anything very serious; it absolutely bellers in reverse, both hi and low.
Thanks for your help,
Allan
RodInNS
12-20-2005 09:21:47
Hi Allan,
I think those hose loops are there to allow for a less rigid connection to the oil cooler. I know that my Fords are the same way, and the coolers are a bit fragile on them, and sensitive to vibration. If the lines were mounted to stiffly, the cooler might just crack and fail over time due to vibration and hose flexing..... With the long hoses, the soft hose does the flexing and leaves the cooler without load. Dunno for sure if I'm right, but it's an idea..... So you're taking this old gal down to bare metal too? She's gonna look as shiny as the rest of the herd? Ah well, I guess it'll keep you out of trouble this winter. Have fun.
Rod
PhilcaseinWPa
12-20-2005 07:20:11
Thats the way they are in my CIH 885 also. I don't know why the loops are there but they are.
Phil
Don L C
12-21-2005 13:25:04
 Re: Before I Do This in reply to PhilcaseinWPa, 12-20-2005 07:20:11
Expansion And Contraction, is my guess....also flex and vibration..... DON L C
Nebraska Cowman
12-20-2005 04:17:15
Looks just like mine. I replaced the hoses on "Bullfrog" one frosty day the first winter I had him after I dumped the hy-trans all over the highway on the way to bait the girls one morning.
Allan in NE
12-20-2005 04:20:10
 Re: Before I Do This in reply to Nebraska Cowman, 12-20-2005 04:17:15
So,
Those hoses do indeed have that big "loop" to em?
Okay, if that's the way they go, that's the way they shall be. :>)
Thanks,
Allan
Nebraska Cowman
12-20-2005 09:19:50
 Re: Before I Do This in reply to Allan in NE, 12-20-2005 04:20:10
No, I don't think the extra hose is nessasary, at least I didn't put mine back that way.
Harley
12-20-2005 07:58:39
Checked into it ole buddy, and it seems IHC in it's infinite wisdom cut back on costs by utilizing the extra hosing for oil resevoir rather than building a bigger tank. Well it could be, :-) Harley. 30 here this morning, supposed to be in the 50's the next ten days.
Don L C
12-21-2005 13:32:47
 Re: Before I Do This in reply to Harley, 12-20-2005 07:58:39
Sorry I an't buying that..... ....
730 virgil
12-20-2005 10:18:21
harley you make me jealous we might get up to 30 on friday we have our high for the day 19 was 2 for low we're having a heat wave the barn cats have taken to using the cover on the cattle waterer for a place to sit to warm their feet
