Tractor Talk Discussion Forum
tractor
carlisle
12-29-2005 00:54:29
I have a 560 farmall diesel that i have bn tractor pullin it has a turbo on it but it keep blowin headgaskets it has been fire ring that didnt help need info on 2 make it better at pullin if n1 could help i gladly appreciate it
ejr-IA.
12-29-2005 11:58:22
 Re: tractor in reply to carlisle, 12-29-2005 00:54:29
I have 2 560's with whistles one is the original 282 and the other is a 301 out of a combine.The 301 has a M&W with a Airresearch TO4 turbo and I pulled it a few times ,run's real good at 2600rpm and 15# boost 2nd gear 6500lb.class.It will push a little antifreeze out the back of the head but haven't blown a gasket yet.THe other one has the old TD9 cat blower kit it's healthy but haven't pulled it, but has around 90HP.I read to use stud bolts and nuts instead regular head bolts that tend to streach more.
ejr-IA
12-29-2005 17:08:38
 Re: tractor in reply to ejr-IA., 12-29-2005 11:58:22
Theirs so many options on building a to4.I use the small exhaust turbine wheel theirs 3 size's of them.Then use a small exhaust turbine houseing I think mines a .54 A/R it's been a long time since I put it together I think it's .50 something,then a small airside turbine wheel and compressor houseing.Used to have a 656 282 with a M&W turbo scrach built by mixing up wheels and houseings and ran 25lb. with a 806 roosa pump,and the IH midgett nozzles,that was a hard running tractor.
carlisle
12-29-2005 14:11:59
thanks 4 the nput ejr-IA i try using stud bolts win i get it back tgether u think i could run a to4 on my 282 and it do ok
the tractor vet
12-29-2005 08:21:07
The problem with putting a hairdrier on them old D282's is that they do not have enough head bolts to hold her down with when ya turn the wick up . Now if ya just farm with it and keep the power down to around 85 Hp. they will do fine . Back many moon's ago a buddy of mine bought a 560D and we installed a M&W turbo and turned up the wick till he had about 110 Hp and had nothing but problems with it blowen head gskt. and then it started cracken heads. End up turning it down and he ran it for many years . They just are not Super Stock material .
carlisle
12-29-2005 11:18:04
 Re: tractor in reply to the tractor vet, 12-29-2005 08:21:07
thanks tractor vet 4 the input but what if i get the block and head o ringed and made my pistons shorter 2 allow mr room 4 air to go n
the tractor vet
12-29-2005 11:28:19
 Re: tractor in reply to carlisle, 12-29-2005 11:18:04
Never tryed it back then and since there is no clear guide lines on tractor pullen engine building ya learn the hard way and make notes as to what does or does not work as far as shaven the pistons down well she will get a bit harder to start and i still think that it is a head bolt issue . Even on the gassers if ya build enough pony power they will not seal all that well . If it was me i think that i would try the O/Ring on the block first before i tryed O/Ringing the head and maybe even getting the head Dowell pinned to the block to keep the head from walking as this also could be part of the problem.
carlisle
12-29-2005 11:35:33
 Re: tractor in reply to the tractor vet, 12-29-2005 11:28:19
thanks again vet i found a machine that wood o ring it 4 a little over 200 bucks.does that sound around the normal price
560puller
12-29-2005 10:49:42
thanks 4 the reply tractor vet what if i shave the pistons down a little bit 2 give it more room 4 the air to go n. im just goin 2 pull it also.
