Tractor Talk Discussion Forum
3020 John Deere convert to 12volt from 24volt
Andrew Lambert
03-24-2006 13:15:50
What all do I have to change to convert a 3020 from 24 volts to 12 volts. This would include 24v generator to 12v alternator and starter as well?
What about the positive ground set-up?
Catskill Pete
03-24-2006 20:50:40
 Re: 3020 John Deere convert to 12volt from 24volt in reply to Andrew Lambert, 03-24-2006 13:15:50
I would suggest you get the kit, pricey but having the correct wiring harness and instructions make life sooo much simpler. On the 3020 you may [depending on the starter] have to replace the twin filters with a JD box filter to accomadate the extra starter length. Can get a bit pricey but worth every penney in my opinion.
don from texas
03-24-2006 20:36:55
Sorry for not reading entire post. I tried to install 24 volt alternator.You are changing both, generator and starter,thats more than I know.
Good luck.
don from texas
03-24-2006 20:07:19
Check archives on this, I asked same question,will not work. Part of wiring is 12 volts and part is 24 volts.What I did was to rebuild battery boxes to hold 12 volt car batteries that have 48 month guarantees.Worked for me.
RustyFarmall
03-24-2006 13:47:37
The most costly item will be the new or rebuilt starter, and a 12 volt alternator will just about always require a negative ground. You probably should also replace at least part of the wiring. Complete kits are available, might be easier than locating each individual part.
