Tractor Talk Discussion Forum
Valve timing on H-Farmall
OS-KY
04-03-2006 18:08:16
What is the way to check valve timing on H Farmalls by watching valve rockers? What no. degrees after bdc or before tdc should no. intake start to open.
Nebraska Kirk
04-04-2006 17:33:40
 Re: Valve timing on H-Farmall in reply to OS-KY, 04-03-2006 18:08:16
There is supposed to be a gap of .017", when the engine is hot, between the rocker and valve when the piston is at TDC on a compression stroke. That is how the valves are timed.
