Tractor Talk Discussion Forum
435D
DARRYL HAZELWOO
04-20-2006 08:56:15
JUST FOUND OUT THAT MY TRACTOR NEEDS TO BE OVERHAULED.NEEDS RINGS ANDINJECTORS.MAKE OFFER.
buickanddeere
04-20-2006 21:16:58
 Re: 435D in reply to DARRYL HAZELWOOD, 04-20-2006 08:56:15
Use the N series pistons, sleeves & N35 injectors. The 1959/1960 issue low compresison S series parts are have been vastly updated. The pistons do not have the spray cooling rods nor does the engine have an oil cooler. So don't oversize the injectors. The blower needs the machining tool and the new seal update kit. There is a new set of HD cam follower springs and HD valve springs to be used. Make certain the cam is reground if it's worn. If the ring and pinion gets tired. The larger HD R&P from a Deere model 1010 prior to serial # 31,000 fits in and works well.
cannonball
04-20-2006 09:37:48
where are you located please...
DARRYL HAZELWOOD
04-20-2006 09:40:17
 Re: 435D in reply to cannonball, 04-20-2006 09:37:48
IN EAST TEXAS.SOUTH OF TYLER.YOU CAN EMAIL ME DIRECT AT WINDDANCERMEADOW@AOL.COM
