Tractor Talk Discussion Forum
my stupid sepentine belt on my 6.2 chevy diesel
tammy724
04-30-2006 16:41:07
ok I know it's a piece of crap lol but it's all ii have. but anyways my darn belt keeps on jumping off. I bought 3 new belts already!!!! does anyone know what that pump thinger is that the belt drives. maybe that is the problem it seems to be turning funny. lol I have a boyfriend that doesn't know which way to turn a wrench maybe one of you real men could help me..... please. thanks boys. tam
Can't even use my name
05-01-2006 13:39:33
 Re: my stupid sepentine belt on my 6.2 chevy diese in reply to tammy724, 04-30-2006 16:41:07
Definately something outta line there or wobbling around. First thing is find out what it is. Second thing is fix it. Third thing to do is ditch your boyfriend... oh! did I just type that out loud? LOL! Surprised no one else said that yet. We must be slipping on account of planting season.
Bud Sather in MT
05-01-2006 08:36:36
Tammy,
I had a chrysler Lebaron that had the same problem. Come to find out it was the tensioner that was bad. Put a new one on, end of problem.
Bud
JM in Merit
05-01-2006 07:30:08
My friend had same problem and his water pump was going out casuing the belt to not run true, repalced water pump, bought new belt and no more problems since then
Joe (Wa)
04-30-2006 22:10:08
Has the alternator or another belt driven part been replaced? Count the grooves on all the pulleys and the ribs on the belt. They all have to match, 5 rib, 7 rib, etc.
Joe
jon holt
04-30-2006 19:56:09
Make sure the tensioner is not worn out and I use a laser to check the alignment of the pulleys.
thejdman01
04-30-2006 17:05:12
Vacuum pump???? Also chekc the tensioner and alignment of all pullies. Post pictures of the truck.
Leland
04-30-2006 16:45:22
Sometimes this is caused by worn out pullys you may need to replace some of them
TimS
05-01-2006 08:07:33
 Re: my stupid sepentine belt on my 6.2 chevy diese in reply to Leland, 04-30-2006 16:45:22
When the belt comes off again, take a straight edge and check each pulley to make sure it runs true. The pump you are talking about is most likely the vacuum pump, the bearings in it may have failed causing it to have enough slop to turn out of line with the other pulleys, making that belt come off after a while. If it is turning funny like you said, you probably will have to replace it. I don't recall how complex one of those is, you most likely can change it yourself if you are skilled enough to put new belts on and have a few tools.
