Tractor Talk Discussion Forum
international 856 fuel pump
cor braakman
06-18-2006 07:40:13
Hello
here's a question from Holland.
I've got a 856 with a roosa master fuel pump, is it easy to "turn it up" so the engine gets more hp? I've got the service manual whit the discription of the work. Is it easy to do it your self or are there a lot of things wich can go rong
ejr-IA.
06-18-2006 11:52:14
 Re: international 856 fuel pump in reply to cor braakman Holland, 06-18-2006 07:40:13
Take the top off the fuel pump and some linkage and turn the leaf spring down tight.Should get you up to 115 to 120hp also you can turn the smoke screw on the outside out too.You will need a allen wrench and a small mirror to tighten the leaf spring down inside the pump.
