Tractor Talk Discussion Forum
Planting Bermuda grass
BKahler
06-30-2006 07:17:20
Looking for suggestions on how to plant some bermuda grass. We're going to be planting roughly an acre. The ground has been destumped, limed and fertilized. The final prep before planting will be running the box blade over it to loosen it up some.
From what I've read bermuda grass should be planted something like 1/2 inch into the ground. After spreading the bermuda would running the box blade over the ground again be sufficient?
The only implement I have to work with is the box plade. Also, the spreader is a 36 inch wide unit. I'm not real sure how to set it up for spreading bermuda. I assume I want to make the openings as small as possible.
Any info would be greatly appreciated!
Brad
Garrobo
06-30-2006 16:25:37
 Re: Planting Bermuda grass in reply to BKahler, 06-30-2006 07:17:20
Last time I planted grass seed I drug it in with an old set of bed springs which I found along the road.
BKahler
06-30-2006 13:24:00
Thanks for all the feedback. For simplicity sake I'll just spread the seed and water. The land is fairly flat so run off shouldn't be a bit problem. We are expecting rain late monday so I'll spread the seed today and water in the morning.
Thanks again,
Brad
jc
06-30-2006 12:07:22
A 4' pallet or skid works well. I use one to break up cores after areation and seeding of my lawn in fall. $0.02
JR-2
06-30-2006 10:50:34
Back several years ago when I was young we would cut some bushes and put behind the tractor and drag them over it ..Have did all kinds of grass seed like this..
slim
06-30-2006 09:40:38
I've had good luck just spreading it on top of soft ground and watering it in. You really don't want that small a seed too deep.
slim
Jim in new Mexico
06-30-2006 13:33:33
 Re: Planting Bermuda grass in reply to slim, 06-30-2006 09:40:38
Hi ,Years back when I did that for a living,I used to drag a long(30ft.) log chain over it to put the seed in the ground. Jim in N M
IaGary
06-30-2006 08:25:07
I don't think I would use that box blade to work in the seed.
It will drag it around and streak the stand.
Try to find somone to drill it for you.
Or find a drag harrow to go over it a couple of times after spreading it with the seeder.
Just my opinion. Gary
Illinois Boy
06-30-2006 09:23:00
 Re: Planting Bermuda grass in reply to IaGary, 06-30-2006 08:25:07
Yep - what IaGary said... You could make a drag out of about anything, but I wouldn't use the box blade.
R. Pugh(NC)
06-30-2006 16:24:22
 Re: Planting Bermuda grass in reply to Illinois Boy, 06-30-2006 09:23:00
Bermuda grass seed are so small that any covering effort will likely put most of them too deep to emerge, I would only water them in to keep from over covering.
