Tractor Talk Discussion Forum
Success Before 8am
Allan In NE
07-01-2006 07:55:37
Hi Guys,
Been fightin' this old frozen front end for 6 weeks now. Every time I'd walk by it, I'd give 'er another shot of panther lube.
Week or so ago, I got the one tube to give it up and early this morning, we finally reached the starting point in the repair, but that sucker fought me all the way.
Now to clean 'er up, install new pin and bushings and slide 'er under that tractor. Whew! I'm tired already and the day is just begun. :>)
Allan
third party image
third party image
third party image
third party image
williamf
07-01-2006 13:48:24
 Re: Success Before 8am in reply to Allan In NE, 07-01-2006 07:55:37
"If brute force doesn't work you're not using enough."
Good work,
Wm
BobMo
07-01-2006 08:33:52
I don't know.....Sometimes its easier if you lossen the clamp bolts 1st..... ...
D boll
07-01-2006 08:16:06
To get tie rod ends out don't heat lay them on the anvil and roll them and hit them on the sidewith a 3-4# hammer, expands them a little and they will come loose. As for your project a couple of CASE tractors hooked to it would have had it loose weeks ago!!!
Allan In NE
07-01-2006 08:21:32
 Re: Success Before 8am in reply to D boll, 07-01-2006 08:16:06
I hear ya, I don't like heat either.
On the existing front end on the tractor, I'm not even going to take the tie rods loose. I'll just crank 'er to the stop one way, pull the tube, crank it over the over way and pull the other tube, move 'em back out of the way and slide this "correct" center section in.
What's a Case anyway? :>)
Allan
old art
07-01-2006 09:48:09
 Re: Success Before 8am in reply to Allan In NE, 07-01-2006 08:21:32
BEER COMES IN A CASE
msb
07-01-2006 08:08:39
AH! Success comes to those who persist.Now put some Never Seize on those tubes when you get em cleaned and painted.
Allan In NE
07-01-2006 08:16:56
 Re: Success Before 8am in reply to msb, 07-01-2006 08:08:39
What?
And miss all the fun next time? :>)
Allan
