Tractor Talk Discussion Forum
MPG with Dodge Diesel
Lincoln
07-25-2006 17:13:15
Thinking about buying a 2002 Dodge 2500 with the Cummings diesel. Just wondering what you guys that have them are getting for milage.
Ohio Mike
07-26-2006 17:41:33
 Re: MPG with Dodge Diesel in reply to Lincoln, 07-25-2006 17:13:15
My 3500 4x4 dually 4 door 6 speed with 35? or 37? ( sorry don"t remember ratio off hand ) but I get 19-21 mpg empty depending on my right foot and that"s all 2-lane and town driving. Towing a 26 foot gooseneck 15000 to 20000 gross tailer and load it gets 17-19 mpg.
26Red
07-26-2006 13:34:56
Before you buy that 2002 get the lift pump and the injection pump checked for proper fuel pressure and flow- it is a common problem with that engine from 1998-2002 24 valve engines. A new injection pump is spendy...
blg
07-26-2006 17:38:57
 Re: MPG with Dodge Diesel in reply to 26Red, 07-26-2006 13:34:56
i have 2002 four wheel six speed diesel .got sixty three thousand on it.check engine lite came on and there is no power below sixteen hundred rpm until i drop in to lower gear and get rpms up then it goes good.i called shop today will take it in monday.up until this no trouble, good fuel milage 19 unloaded 15 pulling goose neck with load.will let you no what the problem is next week
Polish Mike
07-26-2006 10:20:45
Mileage is gonna vary depending on what gears are in your rear, and what kind of transmission...Mine's an 05, 4wd, quad cab, automatic, with 3:73 rear. I'm consistantly getting 18.5 miles per gallon, and my engine isn't quite broken in yet.
George in Biloxi
07-26-2006 13:31:41
 Re: MPG with Dodge Diesel in reply to Polish Mike, 07-26-2006 10:20:45
Same truck, same experience with me too. Loaded or empty. My 01, same as my 05 truck (except it had extended cab) got near 21mpg. "better technology, less mpg".
Bill46
07-26-2006 05:02:04
As I recall there was an engine Cummins made for awhile that is not real good. I have a 96 that has been great.
I hear the new ones are ok...but with electronics just do not get the fuel mileage the older ones did.If I were thinking of a used one I would give Jim Jessup in Columbus Indiana a call. He used to work for Cummins and still has a shop where he tunes 5.9 engines. He knows his stuff. He was a good friend to my dad before his death a few years ago.
I have put an ATS torque converter in mine. Makes that sucker work. She gets around 24 empty and about 15 pulling a 25 foot float.
David in SC
07-26-2006 02:36:12
Hi Lincoln,
I have a 2000 3/4 ton with long wheel base and 2 wheel drive. Six speed tranny. I get 20.5 on winter mix and 22.5 on summer mix. Like others have said, it does not matter whether I drive in circles around the yard, or down the interstate, it is always about the same. Pulling a 6-7K load, I still get around 15.
Great truck.
David in SC
Robert in TN
07-26-2006 00:47:58
A friend has an 02 model with the 6 speed, extra cab, long bed with a topper on it. He gets 18 mpg loaded or empty. Truck really runs and drives great...
Bob
07-25-2006 22:30:15
Clessie Cummins invented the CUMMINS engine.
If you are going to spend the kind of money it takes to own one of those trucks, you might as well learn how his name is spelled!
Alberta Mike
07-26-2006 15:15:28
 Re: MPG with Dodge Diesel in reply to Bob, 07-25-2006 22:30:15
Bob, you are the first member of the correct police to comment on this post. Really, what difference does it really make if he can't spell the word correctly. Obviously you never owned a Messerschmidt or a Peugeot. Now, you don't want to be known as Bob the Knob do you?
Tim Shaw
07-25-2006 21:17:03
I've gotten as high as 20 mpg with my '98, 12V, CTD with the 5 speed trans.
Davis In SC
07-25-2006 18:08:23
My 2001 3500 (6-speed 4X4) gets 18 MPG, empty or carrying a small load, regardless of where or how it is driven, does not matter if it is a long highway trip, or just short local trips. Pulling 10,000 lbs cuts it down to 14 or so.
kyhayman
07-25-2006 18:07:49
Anywhere from 16-19 or so average on my '01 5 spd, with 4:10's long as I keep the RPM's under 2000 it runs to the high end, over 2000 (a shade over 70 in 5th) drops fast. Worst highway I ever got was at 'absolute max' GCVW and I got 12.
Mark - IN.
07-25-2006 17:50:36
Best I ever got with my "02 automatic is/was interstate unloaded at 18 or maybe 19 MPG on average by that meter thing up in the headliner. Worst on average is working around town at about 13 MPG by that same meter thing. I mostly use (work and highway) my "96 that doesn"t have the fancy meter thing in the headliner and don"t ever calculate it, just try to take it easy under all condditions and keep filling the 35 gallon tank as needed.
Mark
